  New Posts New Posts RSS Feed - Xtro flare redevelopement thread
gen0me View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Topic: Xtro flare redevelopement thread
    Posted: 15 April 2017 at 1:35pm
So far I have the shape of horn as stl(in the link).
https://drive.google.com/drive/folders/0B5y23T8xURtGNmZwVlRsM3pmeXM?usp=sharing
Still need to work on phase plug.
I need help in measuring the speaker as on the images: Every 3 cm is good enough.
Have fun. Feel free to check for mistakes. So far I know there is missing 1.8cm length in simulation on size of plywood in front of driver.
Edited by gen0me - 15 April 2017 at 1:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 9:55pm
Anyone has b&c 8pe21 to show or measure? In England?
Actually it should be enough to measure how far is the dustcap from front.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2017 at 12:05am
i have some. i'll check tomorrow if no one else has.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2017 at 2:34am
What are you trying to achieve with the horn design? The sims you've done show a very wide dispersion and a change of 35 degrees in half an octave lower is quite sudden.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2017 at 3:33am
:) I have no goal tbh. Just something that will fit exactly Xtro, may be more universal.
Arent those frequencies where every horn gets directional?
So is it good approach?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2017 at 12:33pm
Not a well designed one, no. A good speaker has consistent pattern control to at least 800-1k, ideally lower. Otherwise half your vocal is immediately subject to reflections or comb filtering.
You would likely do better to decide your design goals and build to that. It would also help to have directivity plots of the HF and LF sections to ensure a smooth transition.
I know of one builders' three way horn loaded cabinet that has HF exactly 60 but the mid horn starts at 90 and ends up at 160 by 400hz, and it's horrendous in multiples.
Edited by toastyghost - 22 April 2017 at 12:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 54 minutes ago at 11:34pm
Here is the original one from https://freespeakerplans.com/forum/38-hosted-plans/5431-x-tro
I see the problem. Conical horn seems to control dispersion better(smaller difrences in frequency change).
This page was generated in 0.031 seconds.
