  New Posts New Posts RSS Feed - 1 2Ch. Amp for 1way mid + 1way hi ?
1ManSoundsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1ManSoundsystem Quote  Post ReplyReply Direct Link To This Post Topic: 1 2Ch. Amp for 1way mid + 1way hi ?
    Posted: 08 August 2022 at 12:40pm
hey,
in about 1 month, me and the dudes will go to the SBG, the biggest paintball event in europe.
since im a speaker fetishist, bringing the music is up to me.
my plan as of now is to bring 4 hd15 and 1 MH122 together with
2 ultradrive (1 as replacement, u never know)
and 2 crown xli 3500 (2 2ch amps)
4 hd15 connected to 1st amp (2 for each channel),
the MH122 connected to the 2nd amp
my question regarding the MH122 is:
is it ok to run the mids on channel A and the hi on channel B?
routing the mid/hi-signal with the ultradrive to output 3/4 and to the 2nd amp.
im concerned about the different loads of the amp. the mids (2pcs. B&C 12NDL76 2x400w rms) are run parallel at 4ohms, the compression driver (beyma CP800TI, 200w rms) is at 8 ohms.
hooked up to 1 amp.
can anyone give me recommendations?
if my idea is shit, i could take a 3rd amp, but since only 1 MH122 is present, running (and carrying)
only 2 amps would be good.
thanks !
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2022 at 1:46pm
running different loads on each channel is fine, preferable even as it allows some headroom on the power supply
monkeypuzzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2022 at 2:21pm
Although many amps will share a power supply internally, you can treat them as two single channel amps from the point of audio signals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1ManSoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2022 at 3:36pm
thx!
at least a little weight off of our backs Smile
