1" Comps above 2" |
Page <123> |
| Author | ||
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 23 October 2008 at 3:55pm |
Have decided on 2" horn + 1" comp route, as that seems one of the more professional moden approaches.
Only question now, what are the sweetest sounding 1" compression drivers from 8khz to 20khz?
High power is not really an issue, as I'm sure even 50W rated drivers, will handle 100W @ 8khz+. Edited by levyte357 - 23 October 2008 at 3:59pm |
Marvin
Joined: 28 December 2007 Location: London UK Status: Offline Points: 1029 |
Posted: 23 October 2008 at 6:32pm |
thats the combo i went with too. As u said power isn't really an issue from 8k up. I use celestion cdx1-1730 above 2"
sKs01
Joined: 11 April 2008 Location: sheffield Status: Offline Points: 1744 |
Posted: 23 October 2008 at 7:23pm |
so how does this fit in with your mid top ideas currently then? still going for a 121? and if so how do you plan to fit the two comps in or are you building something a bit special?
Tekasis
Posted: 23 October 2008 at 7:35pm |
Although that combo should sound good, I doubt that will sound as criss as using separate added bullets / super tweeters!
Pricey ones!
**Heavy Weight-Line**
A home without books is like a body with no soul. |
levyte357
Posted: 23 October 2008 at 8:50pm |
Definitely MT121.
Would need expensive 1" to get anywhere near bullets. But I know a few guys who use Beyma/B&C 1.4" Comps, and say it still has sparkle, so must be a few 1"out there that will do the business. Problem is, I keep hearing about 1.4" comps being blown, which is why I haven't gone for my Beyma 755TI bad bwoy. I'm sure DE25/Celestion CDX 1745 or Beyma CP380 would go sparkle more than most 1"/top $$ 1.4s Edited by levyte357 - 23 October 2008 at 8:51pm |
Marvin
Posted: 23 October 2008 at 8:56pm |
the celestion cdx1-1730 is the neo version to the cdx1-1745 smaller and lighter with no loss in output performance can lend u one each for ur test.
Deadbeat
Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
Posted: 23 October 2008 at 9:00pm |
Get the 2 on a big horn, and hang the 1 in the horn, Apogee style.
High reaching comps, eh? They still make them - look at the FR graphs of the wimpier big name comps. |
Away on extended leave.
levyte357
Posted: 24 October 2008 at 10:55am |
Yup, thats what I'm doing. Research is telling me in terms of 1" B&C/Celestion are the best choices here, even though I expected much from Beyma. However FR graphs for few of the B&C 1" drivers, show dip @ approx 12k, especially DE45. Will hopefully be testing at BMS 1" at weekend. |
Deadbeat
Posted: 24 October 2008 at 11:17am |
Yeah - I can see the break up. Different diaphragm materials ought to fare better. Don't forget the polars
![]() Anyway - good luck with the BMS - heard it and it's quite a nice one. If you want some 3rd part ones - here's a linky: |
breakdabeat pete
Joined: 10 March 2008 Location: norwich Status: Offline Points: 758 |
Posted: 24 October 2008 at 8:06pm |
those celestion drivers look tasty
has anyone on here actually tested any of them yet? |
٩(̾●̮̮̃̾•̃̾)۶
king david
Joined: 17 January 2007 Location: italy Status: Offline Points: 1329 |
Posted: 18 February 2009 at 2:12pm |
today i spent 180euros and bought 2 x de250 ad me45 by b&c, all brand new so i guess i got a really good price. i'm thnking about putting them above 2"horn and let them play 6,5khz and up(as the 2" has a dip at those frequencies). is it better than 4xtweeter horns? i'm also building a couple of monitors with 12"midbass driver...so if i go for the b&c comps above 2", i'll put tweeters in them crossed at about 3,5khz
roborg
Joined: 05 July 2004 Location: United Kingdom Status: Offline Points: 1026 |
Posted: 19 February 2009 at 8:35pm |
I like the idea of something above 2" compression drivers, but to be absolutely honest every time i tried it (like twice) i decided i'd just stick with the 2" exit driver for simplicity. I did use bullets above 2" selenium drivers before, but i used them as a super-tweeter array rather than in anyway time-aligned or even close to the drivers, i xed over at about 7-9Khz
I would say that if 1" compresion drivers are used they must have titanium diaphragms and be on very short horns. I found selenium d210ti's are a really cheap & good for this purpose.
I really want to try some good slots above the beyma cp750tis im using at the moment.
cheers,
Rob.
Page <123> |
