  New Posts New Posts RSS Feed - 1" Comps above 2"
1" Comps above 2"
Big-G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big-G Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2009 at 12:23am
my cerwin vega tops use a 2" and a 1" comp for the top end, i think the 2" does 1k to 6k and the 1" does 6k to 18k
They know what is what but they don't know what is what they just strut what the .
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2009 at 1:24am
Finally tested this combo today. Tongue
1.5khz+ into certain 2",  crossed into 1" using passive xover @ 8k.
Sounded lovely, had to back down on the 16khz quite a bit.. Wink
Problem is my MT121 wont allow mounting of 1" horn above 2", so would have to settle for 1" above in separate box. Confused
Edited by levyte357 - 13 March 2009 at 1:40am
Static Age View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2009 at 9:22am
I'm also going to test this 2" + 1" set up soon, just waiting for some parts to arrive & the time to do it. I'll post my verdict.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2009 at 5:35pm
Couldn't wait to get home and do some more "testing". LOL
put 2" on 90x40 horn, to match 1" on ME45, and it sounded like amp had suddenly warmed up. Tongue
Edited by levyte357 - 13 March 2009 at 5:35pm
sKs01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sKs01 Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2009 at 6:53pm
separate box, or make another box of the same footprint as your mt tall enough for the 1" glue top section on top of the mt and sash clamp or even use a ratchet strap to hold it in place whilst the clue sets? just an idea.
jsg mashed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jsg mashed Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2009 at 7:53pm
No problem here. Just cut a 1" hole in the side or top of your 2" horn, and mount the 1" to that hole (on the outside/back side of the horn pointing inwards).
At over 8K you don't need a horn for the 1" at all.
You want to position the driver so that the sound refects off the opposite side (or bottom) of the flare and emerges pointing directly out of the flare. Off the top of my head a 60 degree dispersion angle (ie each wall angloed 30 degrees outwards) would give you the required beam angle after 1 reflection. You'd want to check that, though.
Added bonus: path lengths may be well matched between 2" and 1".
Edit:
alternatively use the 1" as prt of the phase plug for the 12". Again, don't worry about a horn up above 8K
Edited by jsg mashed - 14 March 2009 at 7:55pm
...because Good is Dumb.
