1 small sub/bass + 2 small tops + build + distro |
Page 123> |
djyves ![]() Young Croc ![]() ![]() Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
![]() ![]() ![]() ![]() ![]() Posted: 08 February 2010 at 8:57pm |
last saturday i bought a new 18sound 15w700 for 15 euro and two p-audio sn-10 mb for 10 euro a piece, i am making boxes for them. here are some pics and plots:
the 15w700: ![]() the 2 p-audio sn10 mb ![]() here is the sub: ![]() here are the plots: ![]() and a bit of the build the wood: ![]() again using biscuits: ![]() glueing the ports: ![]() ![]() Edited by djyves - 01 May 2010 at 9:27pm |
mobiele eenheid ![]() Old Croc ![]() Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
Nice little 6th order BP btw. Any idea's on the tops you're going to use?
Best regards Johan
tops are gonna be vented 25l tuned to 70-75 hz
something like this: ![]() |
made a connector plate + braces + acces panel + baffle with t nuts
![]() 4 of these: ![]() back: ![]() front: ![]() inside: ![]() the speaker: ![]() no panels glued yet. edit: the other handles
Edited by djyves - 19 February 2010 at 5:21pm |
pfly ![]() Old Croc ![]() Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2828 |
Going old school with them XLR speaker connector
Centauri ![]() Old Croc ![]() Joined: 29 November 2004 Location: Newcastle Aus Status: Offline Points: 1792 |
XLR speaker cables only ever used female plugs on each end, so BOTH XLR's on the cabinet should be male. However, speakon connectors should be used now....
BP1Fanatic ![]() Registered User ![]() ![]() Joined: 02 August 2009 Location: Columbus, Ohio Status: Offline Points: 104 |
Nice build & design
cravings ![]() Old Croc ![]() ![]() Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7424 |
agree speakon should be used now.. but i'm sure any speakers i've had with xlr connectors had one of each.. and amps i have with xlr out for speakers.. are male.. so speaker leads do follow the male / female convention..
tops look really nice ![]() |
Here in Aus back in the 70s / 80s, boxes & amps had male XLRs so idiots couldn't use mic leads for speakers.
previous week glued:
![]() and this week rounded the edges, totaly sanded and it sounds nice.
edit: wrong picture Edited by djyves - 19 February 2010 at 10:48pm |
and today i build a distro too
3 phases 32 a 5 fuses b16 1 fuse c16 ![]() ![]() |
Is there any particular reason to use XLR for speaker connector instead of Speakon?
Page 123> |
