1 small sub/bass + 2 small tops + build + distro |
Page <123> |
djyves
Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
Posted: 20 February 2010 at 8:32am |
my bose 802 series 2 had xlr,
so on my hd15's i did xlr too, and here as you see i use again xlr ( and i alerdy have xlr connectorplates for the tops. first I wanted to do speakon but I tought 1 thing xlr so everything xlr.
yves |
backlash
Joined: 11 November 2008 Location: Devon Status: Offline Points: 3532 |
Posted: 20 February 2010 at 8:41am |
What is the reason for using 5 type b breakers and one type c? I assume the type c breaker could be used for lighting maybe? From these pictures also it appears to me you know your stuff and glad to see adequate protection for the outputs. |
djyves
Posted: 20 February 2010 at 9:39am |
1 c fuse for a strobe or something with high peaks
there is coming a output 32 a for linking to other distro's and a fused 3phase 16a output for a distro to other places (truss or something) so only the 3 phase 32a output/link will not be fused (in a few yves
Edited by djyves - 20 February 2010 at 10:31am |
djyves
Posted: 20 February 2010 at 10:29am |
pics of the inside:
backlash
Posted: 20 February 2010 at 10:50am |
Messy but that is to be expected on a DIY build, without using cable ties I couldn't get much better! But I can follow everything yes. Looks safe to me
pfly
Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2827 |
Posted: 20 February 2010 at 11:01am |
few cable ties, may be a bit hot glue and it would look really tidy
backlash
Posted: 20 February 2010 at 11:32am |
Not hot glue, I'd go for the sticky back pads and put extra glue on them as they loose sticky-ness with added heat. Then you can cable tie to the pads and killed 2 birds with one stone!
djyves
Posted: 20 February 2010 at 4:00pm |
yea not finished yet i am going to use cable ties but that is the last what I do, first i am going to make the other 2 outputs.
djyves
Posted: 01 May 2010 at 9:12pm |
I was verry happy with the sub, but I
have blown it 5 minutes ago.was driving on a bridged carver pm 700, so 700 w in bridge, was fine but after +/- 5 sec clipping, the 15w700 was death.
![]() Edited by djyves - 01 May 2010 at 9:14pm |
djyves
Posted: 01 May 2010 at 9:14pm |
Just read the driver was only 450w aes
Teunos
Joined: 23 November 2008 Location: The Netherlands Status: Offline Points: 1832 |
Posted: 02 May 2010 at 5:26pm |
Let me guess, a completely burned out coil, possibly jammed in the magnet or seperated from the cone?
Best regards,
Teun. |
djyves
Posted: 03 May 2010 at 10:15am |
You can't see anything from the outside.
but i think the coil is burned out, at least it smells like that. coil is not separated from the cone.
Page <123> |
