  New Posts New Posts RSS Feed - 10" Coaxial Monitor
10" Coaxial Monitor
L7S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote L7S Quote  Post ReplyReply Direct Link To This Post Topic: 10" Coaxial Monitor
    Posted: 16 June 2011 at 7:33pm
I am building a 10" coaxial floor monitor. I am using bass box 6 pro to help me calculate my required volume for the box, calculate port diameter and length. I am finding some strange results in the CD graph.
As you can see everything below 400HZ is above the XMAX ability of the speaker I am using.
Some info for the speaker and box parameters I am using.
Radian 5210
QTS. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.439
QMS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.22
QES. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.4986
VAS. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.24 5(ft.3 ) , 63.571 (liters)
FS (HZ) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 62 Hz
XMAX (IN) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.035”
RE (Ω) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.98
SD (IN2) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 65.61
The box is:
VB  0.636 CU.ft
FB  79.86HZ
F3  98.9HZ
Vent:
DV 2.5in
LV 0.9391in
Is this ok? or what do you thing i need to do
L7S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote L7S Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2011 at 7:34pm
Steve_B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve_B Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2011 at 8:35pm
I can't see the images, but I would suspect that the quoted Xmax is wrong. 0.035" is less than 1mm. It is probably a typo on the spec' sheet.
L7S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote L7S Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2011 at 11:34pm
Im waiting for a reply from Radian. What if this is the correct number?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve_B Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2011 at 10:49am
It shows you the importance of doing the computer modelling before you buy the drive unit.
0.35" or 9mm (8.89mm for the pedants) would seem more typical for a 12" bass driver.
This page was generated in 0.062 seconds.
