  New Posts New Posts RSS Feed - 10" MT plans
10" MT plans
boots-hifi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Topic: 10" MT plans
    Posted: 12 September 2017 at 3:00pm
Does anyone have plans for a 10" MT 122 or MT 121? I've had a look on the net and hornplans but I can't seem to see anything. Any help would be apriciated.
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 2:44pm
The MT130 on Freespeaker Plans is probably closest to what you want Ben.
Sorry that's 12" as well. Sure I saw a 10" one. Will look again.
Edited by knet94 - 13 September 2017 at 2:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 2:50pm
The MT102 is a doble 10" on here. Sure that could easily be adapted.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 2:59pm
if you go back into the ancient past on here.. james folkes did build some 10" mts. a long long time ago.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 8:26pm
There was a ten mid horn on speaker store but that's no longer up I don't think
If you want people to feel the bass then a reflex design is probably best as you get the most air movement per decibel from those.      errrrr yes wtf?
Mikkel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikkel Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 9:00pm
dont know if its any good for ya but found this ---> http://wizardaudio.hu/hasznos/hangfal%20tervek/top/horn/Fane%20mid.jpg
actually theres a couple on that website, just scroll down and have a look :) ---> http://wizardaudio.hu/hasznos.php
Edited by Mikkel - 13 September 2017 at 9:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2017 at 4:06pm
Cheers chaps I've already got some 10" Fane M's doing nothing at home and fancied making some sawdust.
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2017 at 5:18pm
unless you have a similarly efficient lowmid section that plays up to 200hz+ happily and a HF section covering 900ish up i would not put 10"s in a too short and too small horn like the mt121/130.. if you want/need to make some sawdust though, have a look at john inlows "mid" horns.. fairly easy to diy, simple to adjust/upscale,downscale/sim aswell..?
This page was generated in 0.111 seconds.
