1/4'' jack to xlr insert lead |
Post Reply | Page <12 |
Phil B
Old Croc Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2322 |
And just to confuse you...
watch out for old BSS and Drawmer kit..... pin 3 hot or unbalanced!!! Get those phase reverse cables out ! .p. |
4DPA
Registered User Joined: 11 April 2007 Status: Offline Points: 1127 |
Or indeed the early pioneer djm500's pin3 hot...
though we all know the best place to insert one of those.... dj and bum spring to mind... Edited by 4DPA - 04 October 2008 at 11:37pm |
bs8901 compliant
H...
Young Croc Joined: 21 July 2008 Location: UK Status: Offline Points: 1164 |
Sideways!
Timebomb
And DJM 600s, or at least my one is pin 3 hot.
I thought there was a standard for insert cables, always rememberd it as Ring = Return = Red cable they all bigin with "R". Or rememberd it as tip is left / mono, as on a 2 way jack the tip has to be signal, so on a 3 way jack the tip is still left or hot if its for ballanced. But it seems others do it differently, wich is nice and confusing of them. |
H...
The confusion comes from un-balanced insert points on desks - pretty sure Sound craft have 'swapped' their standard over the years and A&H is different to say a Midas Venice. You don't get this on the big boy boards - except midas with TT jacks for the XL3.
Oh and if you want confusion give a cadac board to a novice - all the pots start at 1 o'clock and finish at 11 o'clock!
CLsystems
Old Croc Joined: 16 March 2007 Location: Birmingham Status: Offline Points: 2736 |
it says on the back of a mix wizard, which is send and return.
