  New Posts New Posts RSS Feed - 12" drivers for live pa
Unknown Enemy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unknown Enemy Quote  Post ReplyReply Direct Link To This Post Topic: 12" drivers for live pa
    Posted: 12 July 2009 at 9:49pm
Just having a think about this really as I'm thinking of getting in to small live pa work.
Went to a local festival today. Just local bands and all that but as you do, you have a look at what pa is being used. Looked home brew. Looked like 1x double 18 or 15 per side with a horn loaded top.
Speakers were massive and tbh, the bass did sound a little one note. Bit boomy but anyway.
After having a play with some sims and after reading threads on here, I was looking at 3x double 12" cabs per side for the bass (not sure about sub)
6 double cabs give around 140db at 54hz but go down to 34hz (133db) before hitting the xmax. The downside is that it requires 7500 watts to get there. Does that sound ok or is that quite a lot?
The idea around this was the small compact size of the cabs. Total size for all 6 cabs is under 500 litres.
Soooo.......good idea or think again?
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2009 at 8:36am
That's exactly what my 12" subs are for except just used a a pair a side. You can run 2 pairs a side (4 drivers) from one of Andy's 5000,s and expect about 131db 137db peak.
You should not need much in the way of LF EQ so that saves loads of power.
If you send me your proper email address I will send you a PDF of the double cab.
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unknown Enemy Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2009 at 10:35pm
Hello Tony,
Thanks for the PDF. Looks like a nice and simple build.
Do have one question. How come the drivers are in a separate box but joined together if you get me? Is this because if one driver fails, it wont kill the working driver???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2009 at 8:54am
Originally posted by Unknown Enemy Unknown Enemy wrote:
Hello Tony,
You can either run it that way or I always put a hole say 150" diameter in the brace towards the back of the cab. when you realise exactly how hot the drivers get it makes sense to me to stop heat rising from the lower driver motor directly on to the upper driver.
One of the reasons I do the ports the way I do is to have a chimney like affect with cold air at the bottom and hot air escaping at the top. I know pepes will take the piss but it really does work.
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unknown Enemy Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2009 at 1:09pm
Interesting.
Is having the port on the rear going to be a problem?
I understand why you have placed the port on the rear of the cab but from most if not all pa speaker cabs, the port is on the front.
Would it work if the port was on the front but was made of flexible tube so it can be directed at the rear of the driver to help aid cooling?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2009 at 5:32pm
Probably just easier to make a shelf port and not be paranoid about temp. like me, or put 2 off 100mm ports at the bottom of the box. Make the box higher to accommodate the ports and just reduce front to back size to compensate. Keep the box at 80L gross volume.
The only time rear ports would cause a problem would be if  you needed to have the box really close to a wall of if you had a big enough stack of them so they started to become directional.
The box is so small I reckon there is always going to be room for a bit of a rear gap.
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unknown Enemy Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2009 at 6:01pm
lol.
Thinking about it, the better you can keep the driver cooler, the longer it will last and possibly more power you can chuck in to them before the limits of the driver is reached???
kevin tyler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin tyler Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2009 at 2:35pm
hello tony
how much does the driver cost in your 12" sub.
it looks very smart and portable too.
cheers
kev
Joe Grime View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Grime Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2009 at 4:49pm
Hi,
Here are a couple of pic's of our Sub12's
link to plans
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2009 at 10:34am
Joe,
Nice looking build there mate.
The thing with the BMS driver is that it is a genuine sub driver and it forgoes a few db of efficiency to achieve that. Having said that because it then requires very little EQ to sound good it can save loads of amp power that way.
I bet your boxes are very good around the kick region? Which driver did you use?
Nice to see someone else that's happy when its small (tale of my life).
Tony
Edited by Tony Wilkes - 21 August 2009 at 12:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Grime Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2009 at 12:57pm
Tony,
 We used b&c 12ps100 drivers, wanted some weight rather than use neo's to stablise poles the for void mycro8 tops. Running them 1 per channel off a void kryo 7. We get a very clean musical bassline from these (bit of eq at 66hz). Sometimes put an X1 under these when heavy sub is required.
