  New Posts New Posts RSS Feed - 12 fane trap for tops
dubwize View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubwize Quote  Post ReplyReply Direct Link To This Post Topic: 12 fane trap for tops
    Posted: 12 October 2011 at 7:52am
Hi .
I'm looking at this design for my tops http://www.fane-acoustics.com/downloads/reflex_enclosure_12.pdf - http://www.fane-acoustics.com/downloads/reflex_enclosure_12.pdf
I'm looking to use eminence 12 delta... not being good at cab designer software, and you guys seem to be well respected.. have you got any idea of port size,length together this to work as a full range.. http://cpc.farnell.com/eminence/delta-12/eminence-delta-12-12-400w-power/dp/LS00189 - clicky so that if I was doing a small gig, I could just take a pair of these. then for big hugs would use four of these for tops, 4 HD15, 2 184 subs
many thanks
Dubz
Edd Jordan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edd Jordan Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2011 at 1:16pm
just build them with the right driver would sound alot better! iv done a rough sim and it looks like that fane 12 box is around 50lts to 55lts  the delta doesn't sim great will be really mid peaky. just find some one on here who has designed a box around the delta 12.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubwize Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2011 at 9:36pm
Cheers thanks for the reply...  would be really keen to look at this fane sovereign 12-500lf   http://www.fane-acoustics.com/prod_details.aspx?pid=202 - http://www.fane-acoustics.com/prod_details.aspx?pid=202   how does this sim? what would be the ideal port size....
really appreciate your help or anyones...
ps what software are you using to sim?
dubz
Edited by dubwize - 16 October 2011 at 9:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edd Jordan Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2011 at 11:52pm
win isd is the best free option there is loads of help on here how to use it.
what about this cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubwize Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2011 at 12:35am
thanks for your help...
it seems  a pick for the fan design or this celestien... http://professional.celestion.com/pro/pdf/12cabinet.pdf - http://professional.celestion.com/pro/pdf/12cabinet.pdf
tried sim using win isd and looks like the fane should work.... -3db at 52hz
box vol about 55L tuned to 50Hz with two vents 75mm dia x 134mm long...  as the 44l seems to small  ..  would welcome coment on this...
2nd question.. if iwas looking at a comp driver http://cpc.farnell.com/faital-pro/hf104/compression-driver-1-40w-8r/dp/LS03740 - http://cpc.farnell.com/faital-pro/hf104/compression-driver-1-40w-8r/dp/LS03740.. I see its rated 40w rms.... what would be the savest crossover point, so that I can run this cab at 400w..
cheers
Dubz
