  New Posts New Posts RSS Feed - 12 inch drivers
12 inch drivers
sounds4u View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sounds4u Quote  Post ReplyReply Direct Link To This Post Topic: 12 inch drivers
    Posted: 18 December 2017 at 8:32am
Hi guys
Complements of the season to you all.
I have 4 single 12 mid high cabs with comps ( reflex loaded ) that I need to replace the 12 inch drivers. I do have 4 beyma cd10fe comps on the shelf which I will use. These cabs will always be used on poles above 18inch BR cabs so don't need it to go to low. It will be used mainly for weddings , party's etc.  Any suggestions will be great.
Peter Jan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2017 at 9:02am
Beyma 12MC500 or SM212
Post Options Post Options   Thanks (0) Thanks(0)   Quote sounds4u Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2017 at 12:27pm
Thank you Peter.
The specs do look nice. Have you heard these particular models, do they sound good?
I have only had experience a few years ago with the Beyma SM112/N and they were good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2017 at 12:58pm
I have used both (others also) in several applications, reflex monitors, 12"+1" tops, closed cab mids in multiway setups.
Other brands and types too, but I seem to remember you said you have best access to Beyma and Faital, so that's why I only suggested these.
