12 inches |
Strange Daze
Old Croc Joined: 14 July 2006 Location: United Kingdom Status: Offline Points: 2861 |
Posted: 02 July 2009 at 4:26pm |
Hey there, I’m just curious, if anyone has any 12” scoop designs handy, or recommended. Cheers, C |
Ibex
Young Croc Joined: 27 May 2009 Status: Offline Points: 1013 |
Maybe these designs will fit...
http://www.speakerplans.com/FORUM/forum_posts.asp?TID=27673&title=peshkov-sub--scoop--tapped--arls greez |
Strange Daze
awesome. Thank you. Did you just scale all the dimensions down...or was there any adjustments?? Cheers!! Edited by Strange Daze - 02 July 2009 at 4:48pm |
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
What are the lowest freqs you are expecting to reproduce? |
adambomb
cos it won't be that low.
I could understand a 12" scoop... if it still had the path length and mouth size of a full size...
Ibex
Just downscaled, no adjustments... Which Eminence driver do you wanna use? |
bitzo
Registered User Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
check the eminence book, it's good start point.
rich_gale
Old Croc Joined: 18 February 2008 Status: Offline Points: 2697 |
scaling a hog down to fit a 8/10" driver in, what sort of response are we talking? 90hz and up? or higher? want to make a 'kick' bin with a direct radiating driver to allow up to a 90-800hz response. will a scaled down scoop of this size have any efficiency benefits in the 90-800hz region when compared against a reflex cab tuned and high passed at around the 90hz point? this will be used as a single cab with a horn dealing with 800hz and up.
bassmish
Young Croc Joined: 28 October 2007 Location: MAAAANCHESTER Status: Offline Points: 1333 |
I think the question should be 'how loud do you want the low f response?'... I'm pretty sure that the main influence of having a smaller driver will not be that it will not play as low but rather it will not play low notes as loud.. you could make a 12'' scoop with extremely similar freq response to 18'', it just wouldn't play the low notes as loud. gotta remember that 5'' reflex hi fi speakers will still play down to like 40hz. Just not as well. |
levyte357
A Correctly tuned 2x12" reflex cab, using Eminence LF drivers, will easily go low enough to play organ notes, at suitable SPL for a house. Few of us had similiar to this in our bedrooms when we were teenagers, rattling the letterbox downstairs. |
fat_brstd
Old Croc Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2126 |
I have a pair of 12 inch scoops that we use for smaller partys and pub back gardens that sort of thing. They do drop low as low as larger driver scoops but they are the same sort of sized box. The spl produced is not as good as that of a bigger driver when driven with the same amount of power.
For a house its pretty pointless as they are still massive boxes. Scalling the design down will just make the horn shorter and thus the frequencies it can hit higher. for really low note you need a really big box.
I would always go with a tuned reflex box for a house if you wanted silly volumes compared to a hifi speaker
Strange Daze
I have a pair of Celestion Truvox 1225e lying around not being used. As these are only for my Hi-Fi...I may change them at a later date...
sorry...I should have been more clear in my first post. I have the eminence book, but am looking for other options also... I may use a car driver thinking about it....they are only for my lounge. Fat Barstard....Its the 'look' im after more than anything. One either side of my TV :) |
