  New Posts New Posts RSS Feed - 12 light connector
12 light connector
BrainlessTekno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainlessTekno Quote  Post ReplyReply Direct Link To This Post Topic: 12 light connector
    Posted: 24 July 2023 at 11:48am
Hi,
sorry but i have no experience with lights so please try to explain even basic details to me :D
Im looking to connect police light in my system but im not sure what to do.
Its 12V so i have autobatery to power it but the light have wierd connector that i have never seen before. Should i cut the cable and look for positive and negative cable and soldier it to make it connect to baterry ?
Edited by BrainlessTekno - 24 July 2023 at 11:57am
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2023 at 12:11pm
tbh, i would crack it open and see what's connected to what inside.
trying to use that connector would be more trouble than it's worth
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainlessTekno Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2023 at 12:34pm
okey sound good... will i be able to identify positive and negative wires by the color or should i check where the wires are going ?
Post Options Post Options   Thanks (1) Thanks(1)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2023 at 12:46pm
dunno, you'll have to work it out, no idea whats inside.
send a pic, can try and help...
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainlessTekno Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2023 at 8:12am
So, i did manage to open it and play with cables. a little, separatly i can power each light that means 4x flashing lights and 6x stropes. however i removed couple boxes from the middle because i was not sure what were they doing.
My next question is...
Flasihng lights are just OK as they are but for the strobes to be used on a gig i need them to flash, i come up with an idea to instal a switch on the cable but who wants to slam the switch every second right ? is there some machine that i can easily install to get the flashing ? how is it called and what are my options ?
