12" quad reflex |
Post Reply | Page 12> |
munkey
Registered User Joined: 17 August 2011 Status: Offline Points: 300 |
Posted: 10 January 2019 at 2:18pm |
I have two 12" quad reflex bins. One is loaded with rig 12p300's. I thinking this would be better for low mid. Any suggestions on 12" drivers that would be good for sub for the other bin? It's about 340l.
Many thanks
the midtops!
munkey
The cheaper the better as well tbh. I don't want to be putting too much money into it
the midtops!
mini-mad
Buy a ton of the Thomann 12w woofers... I've built a few bass cabs using these and got quite a good sound. About £50each and 280w. So for in a cab will be wired to over 1000w of handling at 8ohms.
But don't try to push the sub out, let it roll off naturally or you'll just burn them out. |
IainB
Registered User Joined: 25 November 2016 Location: Rushden Status: Offline Points: 422 |
Why would you buy the T.Box if you need drivers to load into a cab? These are most probably what mini-mad is describing https://www.thomann.de/gb/the_box_speaker_12_280_8_w.htm
munkey
I'm not sure they'll produce the level of bass I'm looking for. I'm tempted by
Or https://www.lean-business.co.uk/eshop/rcf-lf12g301-12-450-watts-8ohm-ferrite-loudspeaker-p-2038.html The sovereign is appealing for its price and looks like it could be alright. The colossus would be better. But is it worth the extra money for the extra output. The rcf seems some where inbetween but also slightly more than I would like to pay. I'm also unsure weather to just have both cabs filled with the same drivers and at the same frequencies. I have no information on the cabs. Maybe have all 8 drivers running up to 120-150 ish to meet the tops. Thanks for the suggestion though. I'll try and find more info on the thommann drivers |
the midtops!
mini-mad
Level? I have a duel 12 reflex sub loaded with a pair of these doing house music every weekend in a bar and the DJ is relentless... these play very well for a loud bar as a pair. 2x cabs loaded with 4 each would play very nicely. And at less then half the price of 2 you have suggested I would be very surprised if you could hear over £200 difference per cab. As a budget loaded cab you won't go wrong.
They are super cheap... no harm in loading one cab up and hearing them for yourself. As budget go they arnt half bad Edited by mini-mad - 10 January 2019 at 9:54pm |
munkey
True. Cheers. How low is your hpf in your cabs.
the midtops!
mini-mad
40hz on a 48db slope
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
Pretty nice Xmax for such a cheap driver
mini-mad
I bought a few to.play with... for a cheap driver they aren't to shabby.
munkey
Is there a block user option on here?
the midtops!
mini-mad
Never tried to... wouldn't know
