12" sub driver |
Page <12 |
Meat Substitute ![]() Registered User ![]() ![]() Joined: 10 July 2020 Status: Offline Points: 56 |
I think the spec change affected the total height of the driver. Don't think it was a parameter change maybe a new frame. I think the issue it caused was the newer drivers wouldn't pass through the doors of MkI punishers.
APC321 ![]() Young Croc ![]() Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 594 |
Some years ago I used to own a pair of "Mega of London" 4 x 12" subs. They were loaded with Beyma L12/P300 long-coil rubber surround drivers.
I was very happy with the performance of the drivers (each 8 Ohm) in these boxes, so long as two amplifier channels (4 Ohm each channel) were used to drive each box. (I did first try powering all four drivers in each box off one amp channel - 2 Ohm load, running though about 10m of 2.5mm sq. speaker cable and it really showed why you should not do this. Really undefined, sloppy bass sound. Last time I ever tried using a 2 Ohm load). Here is a photo of one of the boxes. (Click on the photo to view full size, not sure why just showing small icon). https://ibb.co/Tr1XCXB |
RoadRunnersDust ![]() Registered User ![]() ![]() Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 432 |
That was your problem, not the 2R load 😂
Robbo ![]() Old Croc ![]() Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4187 |
Mega never used any Beyma bass drivers--The original drivers in those cabs would have been ATC or Mega badged Volt drivers.
All of the Mega cabinets that were around the Midlands in the seventies and early eighties would have come from our hire stock or from club installs that we had carried out and those cabinets would have definitely come from one of our two club installs that used that type of cabinet so they were quite a rare box back then. |
munkey ![]() Registered User ![]() Joined: 17 August 2011 Status: Online Points: 298 |
I have two of these boxes in my lockup!!!
Page <12 |
