  New Posts New Posts RSS Feed - 12 v Soundsystem advice.
duhkula View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote duhkula Quote  Post ReplyReply Direct Link To This Post Topic: 12 v Soundsystem advice.
    Posted: 30 July 2011 at 3:24pm
Hey,
So i been reading a lot on this site and found some brilliant advice.Thought i would put my plans to the forum.
So i have a 2 ideas. they are very similar in design in terms of cabinet size. and preferably battery and amp.
Spec 1
Battery  http://www.ebay.co.uk/itm/able-12V-li-ion-Rechargeable-Battery-Pack-9800mAh-/120598545759 - http://www.ebay.co.uk/itm/Portable-12V-li-ion-Rechargeable-Battery-Pack-9800mAh-/120598545759
Amp: Ta2020 (which im sure you will be familiar with.)
Drivers: Eminence Alpha 8" x 2 & some tweeters
Other possible set up is a FUSION 4P-402
  http://www.usfreeads.com/catalogs/204792/item473347. - http://www.usfreeads.com/catalogs/204792/item473347.html (specs)
with alpine sxe 69c2  http://reviews.halfords.com/4028/933101/reviews.htm - http://reviews.halfords.com/4028/933101/reviews.htm with the same battery
its gonna all be rammed into a box with partitions for the drivers dimensions of which are 800 x 350 x 350.
Could do with advice on cheaper or efficiencey of battery amp and speakers and also on whether i could squeeze some 10" drivers in. im currently working on a scale model design on sketch up.
Thanks in advance for any advice, ideas etc
Saturnus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saturnus Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2011 at 3:41pm
Sure it's possible to squeeze in a pair of 10" driver. It's even possible to squeeze in 2 pairs.
My Boominator design is actually 12% smaller volume and has 4x 10" pro woofers, as well as batteries and amp inside.
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine.html
Please note the those CCTV 12V battery packs are not 12V. They average 11.1V since they're 3x 3.7V li-ion cells in series. That has an impact on maximum power output of a TA2020 based amp.
3x 3.7V Li-Ion cells - max output = 13Wrms@4ohms : 7Wrms@8ohms
6x 2V SLA cells - max output = 15Wrms@4ohms : 8Wrms@8ohms
4x 3.2V LFP cells - max output = 17Wrms@4ohms : 9Wrms@8ohms
Not a lot of difference and definitely not audible, though.
Edited by Saturnus - 30 July 2011 at 3:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote duhkula Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2011 at 8:28pm
thanks for the reply, design wise mine is quite similar. although i am fascinated by the solar panels we never have enough sun in england so over here pretty pointless. i spy a couple of LA batteries, would you recommend something like that for my system if the Lithium ones wont work? my friend said something about having to recharge as soon as its depleted etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote duhkula Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2011 at 3:41pm
https://plus.google.com/photos/107124608351673789979/albums/5635897161348836609?hl=en - https://plus.google.com/photos/107124608351673789979/albums/5635897161348836609?hl=en
heres a photo of my design.
i want to put some Fane soveriegn 10" and some tweeters.
using the Ta2020 it would only provide 5 watts per channel to a pair of 8" drivers.
I have a fusion fp 402 would this be better?
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2011 at 4:49pm
Must admit I've wondered this myself .... so just checked a fully charged CCTV pack - measures closer to 12V  than 11V - on my not-very-accurate little meter ...... also thats without load. I think the cells are actaully close to 4V each fully charged/open circuit, so yeah - it makes sense.
But I still say their size/weight makes them a great choice for highly portable TA2020-based systems.
My little system was playing out yesterday - consisting of 2 amplifiers - 6800mAh CCTV battery each - and driving 4 x 4R drivers ......._ really_  kickin up - it certainly _sounds_ bigger/louder than you'd expect .....
... yeah - and yesterday I dared to move the whole lot around on the back of my bike (pedal-bike that is). It _can_ be done - a bit dodgy, but ermm ... yeah - as long as I take it easy with the riding style, it works :-) :-)
2 speaker boxes on the rack at the back ... everything else i.e. batteries, mixer, mic, cables, players - in a rucksack :-) :-)
