121 wedge New build |
Post Reply | Page <1234 8> |
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
Made the prototype on sunday.
Not had a chance to to give it a proper test. I used a bi-amp crossed over at 1.6Khz borrowing a beyma FD-250 today off a friend and then Ill give a bit more testing (In a band situation) It sounds good a little honkey in the lower mid range 100-550Kh ish but there is not padding it the top is amazing. Will post pics later today
dlyxover
Im thinking about handles (one on the top) its really light. top hat need to figure out the best weight distrubiution. speakon placement is vexing me a bit due to it being duel function more pix to come
CLsystems
Old Croc Joined: 16 March 2007 Location: Birmingham Status: Offline Points: 2736 |
put speakons on the end with the top hat?
djtecthreat
Registered User Joined: 14 July 2008 Location: MA (USA) Status: Offline Points: 119 |
I'd put the speakons in the top of the cab above the horn with a recessed dish. You won't ever have it upside down, but you may have it on it's back, sides, or bottom, as well as pole mounted.
CLsystems
or put 2 recessed pairs on both of the rear angled panels. and just link the connectors inside, so they all work
Edited by CLsystems - 11 November 2008 at 9:07pm |
eltron
Registered User Joined: 21 December 2007 Location: Finland Status: Offline Points: 399 |
One on the bottom and one on the top, recessed, near the rear corner. That way you get a nice chain when linking cabs together on wedgework, and when on a speaker stand you can run the cable neatly straight down, no plugs sticking out.
Illustration: Chain of wedges -[_]----[_]- |
dlyxover
Ive got this smaarted yesterday.
It been phase alined and time alined and is nearly flat from 200Hz to 2K smaart comfirmed the f3 is 63Hz Its needed a bit of a bass boost at 80Hz but really impressed with the BMS drives. Compared it with a martin F12 its better gain with out feedback, better bass (my enclosure is really small in comparison) and the f12 sounds like the vocals are coming from the horn only. Ill put the plans and the DSP setting up some if anyone needs a loud compact 12+1 wedge and ill put some finished pix up soon cheers
Edited by dlyxover - 03 January 2009 at 2:55pm |
darkmatter
Have you tried some baffle step compensation, 6db or 3db per octave starting from around 300Hz?
dlyxover
no ive just had a quick read and its over my head.
On the frequency response on smaart didn't deviate more that -/+3dB. I trying to sort a passive crossover for it now and trying to reduce the dsp setting i.e manually time alining the drivers in the box.
darkmatter
Have a read of this, tis a good site: http://sound.westhost.com/bafflestep.htm
Deadbeat
Old Croc Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
Baffle step isn't really needed on a floor monitor as much...the stage is there as a 'baffle' of a sort.
Away on extended leave.
darkmatter
note to self: read the thread properly
