  New Posts New Posts RSS Feed - 121 wedge New build
121 wedge New build
 Post Reply Post Reply Page  <1 45678>
warrenstephenson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote warrenstephenson Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2013 at 11:49pm
Are these plans available
Thanks Warren
dlyxover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2013 at 4:36pm
Hi warren I don't have any plans for them as i got them cmc'd in the end, PM me if you want some as a flat pack
Edited by dlyxover - 27 October 2013 at 6:49pm
In the Truth there is no news, and in the News there is no truth
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2019 at 4:29pm
I've the need for some more of these wedges and decided to rework the design. (yes, Mk6 for these that are intrested)
Same internal volume and tuning, switched to round ports, using 15mm for the cabinet and 18mm for the baffle.
The enclosure is a little taller and shallower than previous design, tended to tip easily if pushed at the top when used as a wedge.
Added a brace off centre to stiffen the enclosure.
Speakon dish on the back and one the base same as before, top hat and one handle on the top.
Foolishly misplaced the router jigs I previously made first job was to remake them.
Baffles up next
Edited by dlyxover - 01 March 2019 at 4:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2019 at 6:43pm
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2019 at 8:33pm
Good work! Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2019 at 10:25pm
6 of the 8 assembled
Good work! Clap
thanks
el chupacabra View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote el chupacabra Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2019 at 3:33am
all hail the mk6! great attention to detail
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2019 at 10:46am
All assembled, filled, sanded, rounded over, filled, sanded, final fill, final sand.
Dose anyone else employ the triple threat filling technique?
Hopefully will get them sprayed over the weekend.
Going with Warnex, was looking at something like Raptor liner but think i'll save that test for a smaller project.
I will be making flight cases for these also, can go into a bit more detail on that if anyone is interested.
(who's got a good solution for off cut storage? I hate throwing birch ply away)
Finjby View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Finjby Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2019 at 7:38pm
Simply simply lovely!  Top work.  Looking forward to seeing them painted.  You do flightcases too?! Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2019 at 2:43pm
Oh yeh, Flight cases too Smile
DIY spray booth
t
This page was generated in 0.133 seconds.
