121 wedge New build |
Post Reply | Page <1 45678> |
warrenstephenson
Registered User Joined: 09 April 2012 Location: bedford Status: Offline Points: 88 |
Are these plans available
Thanks Warren |
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
Hi warren I don't have any plans for them as i got them cmc'd in the end, PM me if you want some as a flat pack
Edited by dlyxover - 27 October 2013 at 6:49pm |
In the Truth there is no news, and in the News there is no truth
dlyxover
I've the need for some more of these wedges and decided to rework the design. (yes, Mk6 for these that are intrested)
Same internal volume and tuning, switched to round ports, using 15mm for the cabinet and 18mm for the baffle. The enclosure is a little taller and shallower than previous design, tended to tip easily if pushed at the top when used as a wedge. Added a brace off centre to stiffen the enclosure. Speakon dish on the back and one the base same as before, top hat and one handle on the top. Foolishly misplaced the router jigs I previously made first job was to remake them. Baffles up next
Edited by dlyxover - 01 March 2019 at 4:30pm |
dlyxover
njw
Good work!
dlyxover
6 of the 8 assembled
dlyxover
thanks
el chupacabra
Young Croc Joined: 02 August 2006 Location: United Kingdom Status: Offline Points: 757 |
Thanks(1)
all hail the mk6! great attention to detail
dlyxover
All assembled, filled, sanded, rounded over, filled, sanded, final fill, final sand.
Dose anyone else employ the triple threat filling technique? Hopefully will get them sprayed over the weekend. Going with Warnex, was looking at something like Raptor liner but think i'll save that test for a smaller project. I will be making flight cases for these also, can go into a bit more detail on that if anyone is interested. (who's got a good solution for off cut storage? I hate throwing birch ply away) |
Finjby
Registered User Joined: 19 January 2016 Location: Shropshire Status: Offline Points: 74 |
Thanks(1)
Simply simply lovely! Top work. Looking forward to seeing them painted. You do flightcases too?!
dlyxover
Oh yeh, Flight cases too
dlyxover
t
