12-inch bass, recommendations please. |
Post Reply | Page <123> |
Author | |||
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 886 |
Now THAT, specifically https://forum.speakerplans.com/forum_posts.asp?TID=92433&PID=1001705&title=the-beginning-of-bliss-soundsystem#1001705 is whatI'm after. It's the sort of crowd that is my bread and butter, and most are younger than me as well Skimming that thread I can see that SW CNC made the cabs for you, and that you have Oberton 700s in them; so SW should be my next port of call and Obertons shou;d be on my list. I can't believe that just last year I sold 4 PD123ER in my EV SX200 cabs - I think thatthey may have been a solution as well. I'm in Bristol so Leicester not reasonably feasible until I get up to Brum to see my daughter.
It's a difficult choice, would you rather have:
A: A vegan son. B: An OnlyFans daughter |
BJtheDJ
This the thing, I don't want/need mighty bass - it would probably frighten mostof my regular punters. 1x12 cabs are the limit, deffo 2 maybe 4, 15's I have and if the Tham 12 is as good as ppl say then they will go.
BJtheDJ
I don't know those cabs, and only a single 12 would be of interest.
Nope, not interested in 15's
You and me both, but I'm 80 miles away and most likely working on the same nights as CookieDJ.
BJtheDJ
Not from what I hear at http://forum.speakerplans.com/forum_posts.asp?TID=92433&PID=1001705&title=the-beginning-of-bliss-soundsystem#1001705 - PROPER reggae would lose me customers
Doubles is not what I need or want. Single 12's will be fine for my market and if I need extra I already have 15's
BJtheDJ
This is the thing. I don't want to move a lot of air, and I already have 15's anyways. A lot of the time I don't have masses of space in which to set up, and I put up a lot of lights as well when needed.
APW
This intrigued me so I’ve just done a very quick and drity frequency
analysis using Audcity on some old classic reggae tracks, quite a few of them drop
like a stone below 50Hz, however they tend to have a massive hump between about
50 and 110Hz. On several tracks that always appear to have a lot of low frequency
content have actually got a fairly flat frequency trace from 60 to about 95 to
110hz, however they drop by about -6db at 50Hz, down 16db at 40hz and at 30Hz down
23db with respect to 60 to 95Hz band. They
also tend to drop by 15 to 20db above about 300hz.
The Bob Marley’s Jammin (as played by cookie-dj in the video in the other thread) and Ken Boothe’s Everything I own both fit this trend quite well, however Jammin doesn’t drop off above 300hz as much as some ( its only about 12db down when compared to the 60 to 90Hz range) and consequently doesn’t appear to go as low as the Ken Boothe track. |
BJtheDJ
I already have 15's, I mentioned them in the start of the thread. And weight is very important to me since 4 my spina; vertebrae are compressing into each other and I have a permanent epidural in my back to keep the pain at bay. I've been doing this for well over 50 years and large boxes have taken their toll.
BJtheDJ
In an ideal world yes; but that's not the world that I play in. Space is frequently at a premium and so is setup and get out time. The people that pay for my bread and butter are not with me to appreciate my wonderful mixing or the fantastic sound, they're there to socialise with each other - and my particularability is to get those people, people that didn't come to dance, up and dancing and enjoying the night more than they would have. So I leave my 15's in the van - I did tell you that I have them in the first postat the start of this thread - even though they can pound it out, because that's not what I need most of the time. It's manily for my satisfaction, and 1x12's will be adequate from what I see/hear of CookiDJ's Than 12's.
BJtheDJ
Thanx for that APW. One of my favourite lovers' trax is Winston Reedy's 'She's the One' and on my present system you can just hear the bottom line disappear occasionally. |
I-shen Soundboy
Registered User Joined: 21 December 2016 Location: Big Smoke Status: Offline Points: 375 |
Really, check out the Q12 design: 14kg with a neo driver/18mm ply.
Truly a one hand lift.
APW
BJtheDJ, I also own 4 tham 12's, if your main work is similar to what is in Cookie's video you will be blown away by them!! Below I've linked to a thread that has the kind of venue I have played at using a pair of tham12s, the thread also has a picture of my small rig.
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
+1 one I-shen Soundboy.
The Q12 is a very impressive box
In the Truth there is no news, and in the News there is no truth
