12mm HD215 |
Nugie ![]() Registered User ![]() Joined: 01 September 2012 Status: Offline Points: 22 |
![]() ![]() ![]() ![]() ![]() Posted: 09 September 2013 at 8:07pm |
Hi
Im about to make my next built and i want to make it as light as possible! I have tried to search the forum to get an answer, but no luck. Have anyone tried to build to HD215 with 12mm ply or is it simply too thin for this type of cab? Thanks |
djeddie ![]() Old Croc ![]() ![]() Joined: 26 April 2004 Location: Bristol Status: Offline Points: 4113 |
Too thin! You'd need so much bracing that you'd probably end up the same weight as if you'd just used 18mm to start with.
Why not just make two single HD15's out of 18mm instead? |
ape3435 ![]() Young Croc ![]() Joined: 23 August 2009 Status: Offline Points: 552 |
Or use 18mm spruce which is much lighter than birch. Did a hd15 once with 12mm birch but used 18mm spruce for the back and 5 part flare, then 18mm birch for the baffle, oh, the HD also had a hi mid and compression driver built on top and I can lift a cab easy enough (neodymium loaded).
Good point djeddie, but in this case the 'issue' is the total weight of the cabs. They need to be transported in various locations where cars cant go. Loaded in the back of a buggy which have weight limitations. So every kg count (:
Ape, do you have a photo of that cab you're talking about? It sounds interesting. |
Teunos ![]() Old Croc ![]() ![]() Joined: 23 November 2008 Location: The Netherlands Status: Offline Points: 1788 |
If you're talking about loading them in the back of a buggy, are you sure HD15 is the way forward? The HD15 don't really drop below 90Hz so are pure kick only, no sub at all.
Best regards,
Teun. |
Timebomb ![]() Old Croc ![]() ![]() Joined: 11 October 2004 Location: Lancaster Status: Offline Points: 2703 |
HDs drop to 55-60Hz in multiples, i dunno why people use them for upper bass cabs, 50-50Hz to 130Hz is the range they do best. 12mm birch would be fine if you double braced them throughout, would save some weight for sure and probably be less resonant than the original plan.
Haven't at the moment but could probably put a pic or two up tomorrow. Nice light weight cabs they are. |
Been busy at work so nothing have happened yet.
So... I came across another kick bin (Bootybass, davey t) the other day and thought it looked interesting. The cab is smaller and use a lightweight driver (fane sov 15-400/600lf). Have anyone tested these two cabs up against each other to see which on performs the best? I plan to make 4 hd215/bootybass which will be split up in two stacks. The cabs will mainly be used outside and will be playing as standalone bass/kick cabs!
