  New Posts New Posts RSS Feed - 12v campervan Minirig
dnbpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnbpc Quote  Post ReplyReply Direct Link To This Post Topic: 12v campervan Minirig
    Posted: 06 June 2019 at 10:39am
Hi all,
I recently put together a minirig to take with me in my campervan but after a month on the road it's proved to be too heavy and a pain to set up with the generator etc...
I've now decided to downsize and go 12v and wanted to run the plan past a few people here first for advice before I commit to the build. I'll mainly be travelling in warm sunny countries so want to utilise solar power for charger as I'd rarely have access to mains supply.
Battery - 110ah leisure battery
Amp - bassface db4.1
Tops - I have a pair of logic is10s 200w speakers in the existing minirig so was going to use one of those
Subs - I have a b&c s15an cabinet loaded with a b&c 15ps100 700w and I also have 4 beyma 8br40/n 50w drivers to hand which I was planning to stick in a quad box, which of these would make the most use of small amount of power available?
Are there any other pieces I'm missing or any better solutions?
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 07 June 2019 at 2:40pm
I'd say replace that amplifier with a full-range class D one.
Look at 4-channel ones from the likes of Pioneer, Alpine, Vibe etc.
The idea is to use it as a 2 channel amp, but 2 bridged channles driving a 8R load is a sensible impedance match ... so 1 pair of channels driving your mid-top and the other pair driving the bass box - using the built-in HPF/LPF  should be OK ....
Edited by slaz - 07 June 2019 at 2:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnbpc Quote  Post ReplyReply Direct Link To This Post Posted: 07 June 2019 at 3:41pm
Cheers I’ll take a look at a few of the options.
Would you say I’m best sticking with the 700w b&c driver and feeding it around 100w or making a quad box with the 50w beymas although this would take the impedance to 2 ohm?
