12v + coax 1.4" + 1" |
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
Posted: 14 May 2020 at 11:42pm |
This is the Mk2 I've done of this enclosure.
The Mk1's are made from 18mm ply. The 12s were ported into dead space behind the horn, more to give a taller cab more than anything else. The Mk2's are made from 15mm apart from the baffles which are 18mm, still got to make the wheel boards. They are significantly light and more compact with the same performance as the Mk1's. Work well as a full range enclosure or sat on subs. new subs are next on the build list. Current favourite 18" drivers for reflex enclosures? Currently use a BMS 18S430v2.
Edited by dlyxover - 14 May 2020 at 11:54pm |
In the Truth there is no news, and in the News there is no truth
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
Fantastic build :) Is it a coax HF?
dlyxover
cheers, yeh BMS 4594.
A beast of a HF unit, can keep up with 4x 12"
cravings
Lovely indeed. Is there a wheelboard to come?
What 12s? Great finish on them. |
dlyxover
yes wheel board to come.
Going to do it same same as the Mk1's, admittedly not the best option but is functional. They did have a tendency to rack if twisted and come off but some blocks on the wheel board that fit tight on the cab stop the racking. To compare the size difference Going to do it same same as the Mk1's, admittedly not the best option but is functional. They did have a tendency to rack if twisted and come off but some blocks on the wheel board that fit tight on the cab stop the racking. Using BMS 12N620's (I like BMS driver if you can't tell) Finish is Warnex sprayed with a pressure pot system.
