15 inch bass horn for 40-200Hz |
MrScy ![]() Registered User ![]() Joined: 23 June 2017 Location: South Africa Status: Offline Points: 26 |
![]() ![]() ![]() ![]() ![]() Posted: 24 November 2018 at 3:14pm |
Hi all,
I am looking for a plan of a 15" bass horn that play 40/50Hz-200Hz and it should be efficient. Size is not an issue but I would consider something that is not very large and not very difficult to construct. Was there ever a 15" version of the invader bin?
montek.co.za
Jo bg ![]() Registered User ![]() Joined: 08 March 2017 Status: Offline Points: 204 |
Horn loaded, small, easy to build and down to 40 Hz is not possible.
Horns need to be big and long to load down to 40 Hz,, and need to be bent if you don t want a 3 meter long box, so difficult to build. Small, wide frequency range and easy to build means just reflex. Modern drivers and amplifiers will give you great powerhandling with little weight, this should overcome the lost efficiency to an extent
Meat ![]() Young Croc ![]() Joined: 05 June 2009 Location: Manc Status: Offline Points: 1428 |
I don't think you'll find anything that'll do up to 200 and down to 40 although if you get a big enough pile of Martin 215 mkIII (6 or 8 of them) you should have an extremely high impact system which should do pretty much do that. Maybe more like 40-150. Can't remember what James F said his settings were. |
