  New Posts New Posts RSS Feed - 15 inch cyclops
15 inch cyclops
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2014 at 6:18pm
Yes Danley TH115 and TH118 are essentially the same box. But the driver in the TH118 is something on at least 2 levels above the one in the TH115. Using the scale up and down approach used by some people, they should have made the TH118 bigger. But they didnt. So it is not as easy as it looks.
rhuet99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhuet99 Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2014 at 7:31pm
I built a pair of cbe-18.  With discussion and input from Stipe, I loaded them with Kappalite 3015LF and they work well.  The only change was in the baffle which was cut to suit the 15 as opposed to the 18.  All I can say is try it.  You can always rework the baffle to suit an 18 if the result is not satisfactory for your particular application.
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2014 at 1:08am
"The Danley 15" and 18" are the same cab "
No, they are not.
The external dimensions are the same, but the internals are longer in the TH118. This info may be gleaned from the impedance plots.
I would wager that if you model the Cyclops with the higher Qts 15's that it will look good without having to cut the height down much if any.
Edited by _djk_ - 12 September 2014 at 1:09am
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2014 at 1:57am
According to Tom Danley the box is the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2014 at 2:31am
The data he publishes contradicts this statement.
Edited by _djk_ - 12 September 2014 at 8:04am
djk
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2014 at 5:47am
Hornresp can settle this. Who's got the input for the cyclops?
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2014 at 6:20am
taken from this thread
bcs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcs Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2014 at 7:35am
No, they are not.
Hi Djk. do you suggest that i build the cbe18 but and use the 15"driver or build the shorter version of it?
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2014 at 7:57am
You may be able to build it pretty much as-is for a high Qts driver like the Eminince 3015LF or 4015.
The lower the Qts of the driver, the smaller a throat it likes to see.
I suggest you model it with the driver you will be using, just to be sure.
djk
bcs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcs Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2014 at 8:24am
The driver will be the beyma 15p1000fe as i have 4 of them already.
ShokZi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShokZi Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2014 at 9:23am
its definitely possible, but that dip in the middle of the response will probably get more pronounced and excursion will prob go through the roof...
