  New Posts New Posts RSS Feed - 15 inch scoop design: opinions
TomLMS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomLMS Quote  Post ReplyReply Direct Link To This Post Topic: 15 inch scoop design: opinions
    Posted: 20 September 2023 at 2:03pm
Hi,
I'm trying to design a modified scoop for the pd154c001. It's the first time I that tried to work with hornresp and autocad, and I'm not trying to built 'the best box in the world', just something that I modified myself and that doesn't perform awful.
I've added the schematic of the design and two different hornresp inputs & power output (different 'width') (It's a google drive: https://drive.google.com/drive/folders/1F5K0qPVkmAF95niHlVGrmACvMerqoBkL?usp=sharing).
My question is: What do you guys think of the design? Which width looks better to you? Other remarks?
Let me know what you think, all input welcome :)
PS: If this should be in the newbie-segment, just let me know and I'll delete the post :)
Edited by TomLMS - 20 September 2023 at 2:22pm
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2023 at 8:36am
Quick look at the T/S parms, for that driver, tell me, what I already know.
In 2023,  drawing Scoop for a 15" driver, is rather pointless.
Would suggest, you acquire the plans for the Staiper 18" mini Scoop, and try to mod that for a 21".
Smaller, and would blow away any 15" full Scoop, if done right, with right driver.
King Simeon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote King Simeon Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2023 at 9:47am
A key point you need to make clear is what you want the box to do for you, what is it going to be used for?  This should be a start point before committing to expectations.
https://www.facebook.com/KingSimeonSound?ref=stream
https://soundcloud.com/king-simeon
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomLMS Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2023 at 10:44am
Currently, i have two 12" scoops that are okay-isch, but I want to upgrade because the 12" just can't hold up compared to the rest of my (reggae) soundsystem. Friends of me also are playing with 15" scoops, and when I played on them I wasn't dissapointed. Since i think that there are enough soundsystems that use 18", I wanted to go with 15" scoops, because being the loudest doesn't interest me.
So what do I want: I find 15" drivers loud enough for what I want, so now I need a box for it. There aren't many 15" designs online, so I tried to draw something myself. The question I have now is: do you see (major) flaws in the design? Does the hornesp look decent or not? ...
cardiffdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cardiffdon Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2023 at 6:25pm
Staiper 15" Scoop.
Es15-BLH (Baby Hog)
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2023 at 8:33am
Originally posted by cardiffdon cardiffdon wrote:
Staiper 15" Scoop.
Es15-BLH (Baby Hog)
Yep, better this, than trying to run, before you can walk.
Edited by levyte357- - 22 September 2023 at 8:33am
