15' kick cabs |
Post Reply | Page 12> |
JamesFlipside
Registered User Joined: 14 July 2012 Location: London Status: Offline Points: 162 |
Posted: 21 November 2012 at 2:16pm |
Hi all,
building a rig and thinking about the best type of cab design to fill our hole ;) I dont know that much about design so more looking for pro's and con's from experienced builders/engineers. Basically what i'm moving towards is putting together a OEM'ed rig. Got some twin 18' PD loaded subs that are a design i love, sound awesome... They are basically reflex subs similar to something like a DB DVA S30N - but not as DB sounding ;) The design can be rear loaded to make them more similar to a horn type and that is how we run them as they sound warmer and rounder on the <72Hz freqs. Buying some SP12s of Mykey and some HF horns too so those will be the top end. What we dont know is what to do between them??? Front loaded? reflex? horn? 15's ??? We are going for the purely dance sound, hard but not harsh sound. What type of design would be best suited to fill the gap between the sub and SP12? We want that full, rounded kick to suite techno/house stuff. Thanks :) |
"DFA switch fitted"
king david
Young Croc Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
hd15: 15" loaded and good for kick... or similar style of cabs based on the old turbosound bandpass horns
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
15 feet????? Boom-boom.
It would probably suit you to look at the Turbosound kick, HD15-type as mentioned before to get that dance thump. |
grazzeee
Registered User Joined: 06 July 2011 Location: Portsmouth Status: Offline Points: 440 |
what freq range are you looking to run you kicks?
JamesFlipside
between 72Hz and 220 ish
"DFA switch fitted"
njw
Old Croc Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2572 |
HDs wont go that high without sounding honky, IMO about 150hz is as high as they go, perhaps a decent reflex box would be better?
mykey-
Old Croc Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6114 |
QSS
Old Croc Joined: 21 July 2009 Location: Bristol UK Status: Offline Points: 2414 |
ASS BS500 is the best sounding 15" I've heard on kicks andit will go up to 250hz easy without sounding honky.
If its a box you want to build yourself then a ES15 (modified ES18) with the right driver would also do the trick. Not a lot of 15" kicks will play upto 250hz without sounding a bit honky.
"Music is life"
njw
I was thinking of ASS BS500/600/1200 when I posted but wasn't sure how high they played.
mykey-
Go see Goliath (PBS) and get my hybrids made up
JamesFlipside
I'm using the double 18 Davey T's booty bass subs. Then two single 15's to increase modular flexibility. Then one SP12... You think? In application the SP12 will be slimmer than the footprint of the overall stack so would play out more like 2X 218 subs, 4x 115 kicks and 3x SP12+HF per side. |
"DFA switch fitted"
Karlsonman3
New Member Joined: 07 April 2012 Status: Offline Points: 3 |
Karlson resonators can be "kicky"
