  New Posts New Posts RSS Feed - 15" Kick Scoop Idea??
SmokeyJoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmokeyJoe Quote  Post ReplyReply Direct Link To This Post Topic: 15" Kick Scoop Idea??
    Posted: 18 January 2008 at 12:34pm
Just been browsing the Scoop forum, getting envious of all the guys with their "premier league" 18" Scoops. I am particularly interested in the HOG scoop. Due to its re thought design.
I know that many people have trouble getting a great kick box to go on top of their 18" Scoops and thought about what a great Kick I remember 15" Scoops to have...
So I've come up with this - never designed a proper speaker in my life before - so it may be sh*t. But I really want some comments!
Just popped into my head lol. May make some dimensions up and build a pair just for the crack.
What do the more experienced guys think? Would it work?
- Joe.
josh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote josh Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2008 at 12:38pm
yes it will work its just like anyother scoop, you have to be more calculated than drawing it on paint though, your going to need to simulate it on the computer and come up with some real dimentions, weather it will kick or not is another matter, scoops have phase issuses where sound from the driver is in or out of phase with sound comeing from the horn depending on the fequency being played so you could find you have a dip in the response around the 80-100hz area like most scoops do and thus no kick
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2008 at 12:47pm
One of the problems you might encounter is the phase cancellation between the direct radiation and the scoop popping up in the range you want to use.  You'll also need a small rear chamber I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmokeyJoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2008 at 1:22pm
Ah, I forgot about the phase cancellation thing with Scoops. Seems it may not work in the right range then...
I may continue to tweak the design into a build-able cab - and then do an mdf prototype.
And I first drew it up by hand, on paper. I just used paint to get it on the forums - thats no where near a plan - I only had the idea 30 mins ago!
- Joe.
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2008 at 1:26pm
but as the horn path is much smaller, wont the cancelation happen at a higher frequency than you'll be playing them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2008 at 1:27pm
100Hz is 343cm so if the horn was 170cm it'd be perfectly in phaze at 100Hz, am i right?
tommysb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommysb Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2008 at 2:13pm
You also have to consider where the scoop mouth is smaller than the wavelength produced it acts like a transmission line, and the wave reflects back down the scoop. You have the 180degree phase shift since it comes out the back compared to the direct radiator. You when have 1/4 wave going down the scoop, another 1/4 reflecting back (so in total a 1/2 wavelength phase shift).
THis 1/2 wavelength shift is for the '180degree' shifted radiation, so now, you have it in phase.
The ammount of 'refelection' back up the scoop is frequency dependant. But the point is at some frequencies you're gonna get interference and others destruction. I don't know if this is expressed very well, sorry!
Static Age View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2008 at 2:28pm
i agree with the above points.
smokeyjoe, also take into consideration the size of this potential cabinet for your proposed aplication. scoops are pretty large cabinets, using a scoop sized cab above them for kick bins means even more big boxes to have to carry/ transport.
i think if i were to go for a kick bin above my scoops it would have to be nice & compact like the HD15 for example.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmokeyJoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2008 at 2:58pm
Well, it is intended to run 70~140Hz. Its not by any means a long horn, and wouldn't be that much bigger than a HD15. It would be as wide as a Scoop and not very tall. Designed to stack on top of a vertical row of Scoops.
Does anyone know of any FREE MAC-FRIENDLY software I could use to model this?
And, its only for fun - nothing serious. I just hope its loud .
Thanks, Joe.
