  New Posts New Posts RSS Feed - 15" midrange horn plans?
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2008 at 11:08am
The tweeters im using can be found here;
Ideally i wanna run the 2 x 15" as low mid and the 2 x 12" as high mid
I wonna make a double box front facing for the 15"s any ideas for plans?
And i need plans preferably the old eminence flares for the 12"s if anybody got them?
Smile
Death_blooms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Death_blooms Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2008 at 11:28am
the tweeters wil be fine. so what plans are there that would work for me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Death_blooms Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2008 at 2:54pm
bump...
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2008 at 9:10pm
If you have no horn on the box its easy - just knock up a 3cu ft box with 50hz tuning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Death_blooms Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2008 at 11:38pm
for future reference how do you know how large the box must be for a certian driver? and 50hz tuning? whats that?
also can i put a horn path of any size infront of this box?
thanks for your help guys
Edited by Death_blooms - 03 March 2008 at 11:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Death_blooms Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2008 at 7:48pm
bump...
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2008 at 4:53am
If you get Fs Qts Vas you can calculate the correct volume for woofer. Download winisd pro from www.linearteam.dk for a start.
Whats 50hz tuning?You tune the port to some bass frequency and it increases output.
I think I suggested a horn at the beginning,and after deciding on no horn you want one again?lol
Stick with no horns unless you need them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Death_blooms Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2008 at 9:19pm
i cant make my mind up sorry its alot of money to spend so i want to know that im makeing the right decision
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 6:29am
How about lets make a conclusion
Small venue
less than 200 audience
No reason for extra low frequencies
X15 or x12 + reflex sub.
Id guess that the x12 may sound abit smoother due to the HF driver not having to go so low.
Also a high frequency horn that has 90*x40* Dispersion is a good idea if using one per side.
If you were going to use two per side- with 60x40 horn,you could try splaying them horizontally side by side.
Problems?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Death_blooms Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 6:23pm
with this app does it take into acount the amount of space the driver will take up inside the cabinet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 8:57pm
Nope,it doesnt do anything for you.
VB = AIR inside the box.So you work out the box,then manually add driver volume,port volume,to get your total internal volume.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Death_blooms Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 9:52pm
ouch... so i take it the size must be accurate. I dont know where im going to get info on the volume of the driver.
