15" midrange horn plans? |
Page <1 234 |
tb_mike
Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
Posted: 19 March 2008 at 4:29am |
\Just find out how much volume a 12" driver has. Or whatever size woofer your using. They tend to be quite similar. It wont be much,just a litre or three. If you dont consider the driver volume,the port volume,nor the port wall volume,yess your tuning will be a little off. But if you get close enough within 5% thats ok. Its not like your going to tell if your sub is tuned to 49hz instead of 50hz. |
Steak'n'ale
Joined: 31 January 2008 Status: Offline Points: 165 |
Posted: 08 April 2008 at 4:05pm |
I've used the 12" midrange horn from the eminence book loaded with fane colossus 12" they were good. Big cab for just a 12" though. 4 of them from 180Hz-3500Hz sounded pretty good.
Overkill for 200 people mind... ...unless they're outside. Its a bit of an old design and the mid horns on SP are probs better but they work. They do have a curved horn though, but whats the problem with that? |
Drimacoustic
Joined: 01 July 2006 Location: Slovakia Status: Offline Points: 132 |
Posted: 08 April 2008 at 6:42pm |
Have ever anybody tried Selenium PASxxx plans? I tried to simulate them in HR, result was not good.
I am looking for 15" straight horn to cover 100Hz to 400-600Hz, above will be this http://eshop.prodance.cz/DetailPage.asp?DPG=85334 horn and top should be D210Ti or another 1" comp. Any suggestions? sry for bad english Drim |
love begins below 40Hz
Death_blooms
Joined: 03 November 2007 Location: United Kingdom Status: Offline Points: 98 |
Posted: 08 April 2008 at 10:10pm |
where can i get hold of the eminence book?
justamadman
Joined: 13 May 2007 Location: United Kingdom Status: Offline Points: 1118 |
Posted: 09 April 2008 at 12:27am |
all you Norfolk free party crews should heed this warning................ you know who you are |
in front of the bass bins baby
Steak'n'ale
Posted: 09 April 2008 at 11:57am |
You used to be able to buy it from good ol' Maplins. I have to admit I just photocopied my mates copy though. |
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 09 April 2008 at 1:56pm |
FFS! SEARCH!!!
http://zmatek.jinak.cz/diy/_upload_by_VeeHell/speaks/eminence/mediumbedny3.pdf |
insert silly sentence here
Jake_Fielder
Joined: 08 October 2007 Status: Offline Points: 4236 |
Posted: 09 April 2008 at 2:30pm |
Someone might be able to help you better if you started a new thread, this thread is going nowhere!
Mark James
Posted: 09 April 2008 at 2:38pm |
sellenium hb1505c1 80hz < probably to 600 more likely 400 though, straight 15" horn!!! will take pd158 and kappa15 no problems, fusion julze has some for sale that if I were more wallet endowed would no longer be for sale and would be in my lounge!
Page <1 234 |
