+/- 15&12v Power Supply |
Page 123> |
kr1sounds
Joined: 28 June 2014 Location: ThePromiseLand Status: Offline Points: 920 |
Topic: +/- 15&12v Power SupplyPosted: 15 August 2014 at 9:23pm |
Done a bit of research and decided to make my own.Im not sure if it works yet will test soon..
![]() If anyone is willing to test please do and let me know Cheers
fostonshfs.webs.com |
mini-mad
Joined: 13 July 2012 Location: london Status: Offline Points: 6861 |
Posted: 15 August 2014 at 10:00pm |
...what are the 78XX rated at? and what is it powering?.... i ask as i HAVE build somethis imilar and i had 2amp 78XX chips and they got nice and hot wen "driven" hard.
kr1sounds
Posted: 15 August 2014 at 11:08pm |
im not sure, ill have a look. im looking to get a high current out of them so i'll be putting them on heatsinks
kr1sounds
Posted: 15 August 2014 at 11:11pm |
1.5A for a preamp im building
audiomik
Joined: 06 April 2010 Location: Bath, UK Status: Offline Points: 2956 |
Posted: 16 August 2014 at 12:53am |
Have built many PSUs of the type in your circuit diagram.
You should add load resistors to the outputs of each of the Regulator IC's. Have another look at the IC Datasheets in the applications and test circuit sections. This guarantees a minimum current at the IC output. Next is to add suitable diodes to prevent reverse biasing the ICs when powering down. Also a good idea to have a LED for each output to easily see if you get a fault condition hope this assists Mik Edit: korekt schpeling Edited by audiomik - 16 August 2014 at 12:55am |
Warning! May contain Nuts
plus springs, washers, screws, etc, etc. |
dj jammin
Joined: 10 April 2010 Location: southampton Status: Offline Points: 773 |
Posted: 16 August 2014 at 7:48am |
Why do you need the +/- 12v?
Reverence Sound system
kedwardsleisure
Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 5157 |
Posted: 16 August 2014 at 9:35am |
your rectifier diodes don't quite look right
North Staffordshire |
JR.junior
Joined: 14 December 2009 Location: Slovenija Status: Offline Points: 1789 |
Posted: 16 August 2014 at 12:00pm |
yes, turn it cw for 90 degrees.
kedwardsleisure
Posted: 16 August 2014 at 2:01pm |
that won't work either.
You've got 2 diodes the wrong way round. In the pic your mains transformer will lead a rather warm, if short, life. Clue: a bridge rectifier will have 4 connections. Yours has only 3 Edited by kedwardsleisure - 16 August 2014 at 2:02pm |
mini-mad
Posted: 16 August 2014 at 2:10pm |
....and theres me just skipping over the design with disregard and an assumption that the bridge was correct lol
JR.junior
Posted: 16 August 2014 at 2:59pm |
2 diodes diodes wrong connected, oversaw that.
kr1sounds
Posted: 16 August 2014 at 3:42pm |
for the vu meters
Page 123> |
