  New Posts New Posts RSS Feed - 15mm/19mm/20mm. plywood?
kunak23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kunak23 Quote  Post ReplyReply Direct Link To This Post Topic: 15mm/19mm/20mm. plywood?
    Posted: 26 April 2009 at 10:59am
I went yesterday to a couple of stores to buy wood to make a X1 and i fond a problem with the mm deep of plywood,  i only found 15mm deep, 19mm. or 20 mm. , anyone could suggest wich one should i go for? Beacuse i have to reset some measurements on the plans.
Thank you¡
