15n630 box |
Post Reply | Page 12> |
JonB67
Posted: 31 January 2017 at 10:32pm |
Sim'd the 15n630 up in winIsd.
Ended up looking at 120 litres and 40hz to get the extention I want at the bottom end. Given bms recommends 90litres and 43hz what's the trade off going slightly bigger? Worried it might sound looser? Thanks for any help Jon |
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2544 |
Did you check cone excursion at rated power? You are probably way over with that larger box.
JonB67
I did check that in the sim. at xmax with its full 600 watts.
to be honest it seems to sim better than the 90 litre bms recommend for this driver but I'd prefer the 90L for transport! |
odc04r
With the Qts and Vas figures for that driver you are in the right ballpark I would say. It's a very compliant driver compared to others in its class. These numbers together do suggest a large reflex box.
If you are after a smaller box I'd probably be looking for a driver with lower Qes and lower Fs. |
JonB67
I already have these drivers new from Bee so they'll be what I'm using.
I had to go read up to find out what you just said actually means! Its been a pretty unforgivingly steep learning curve - I'm trying to understand rather than just fudge my way through! I've spent several hours reading and playing with the sim and am unsure between the 90 and 120 litres now. Don't know how to decide. Perhaps either will be fine?
odc04r
Hah, no worries. It's a driver that likes a slightly bigger box than a lot in its class if you go for what is known as a maximally flat reflex alignment. If you are willing to tune a bit higher then you can make the box a bit smaller too. Personally I think I would be looking to tune those ports to about 45Hz and would then size the box accordingly for a decent response. Maybe not maximally flat, but as long as output was good around 60Hz I'd be happy.
Also bear in mind that resonant frequency for these guys is listed at 39Hz so you want to go a bit higher than that ideally otherwise you might get some interesting interaction depending on what ends up being exactly what. 45Hz is probably a fairly sensible idea from that point of view. Due to manufacturing tolerances the numbers in reality are rarely exactly what is listed. Edited by odc04r - 01 February 2017 at 10:36pm |
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
Isn't that driver the neo version of the s330 ? If so why not have a look at toys Q15 design for the 15s330 might give you some ideas
GOD TOLD ME TO DO IT !!!!!
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Personally I'd go for the smaller box. You can EQ its response but you can't EQ it to fit in the car.
triumphant
New Member Joined: 02 February 2017 Location: South Devon Status: Offline Points: 5 |
It sounds like a good project. I'd be interested to read about your results once it's finished
JonB67
Was wondering if anyone would be interested in a novice build thread or if there's no real value in it.
I'll take some pictures anyway! |
cookie-dj
we all love a build thread on here
You can't polish a turd!
djscooby
Young Croc Joined: 15 March 2008 Location: United Kingdom Status: Offline Points: 1414 |
+1 Noob to building P.A gonna do my first build in the next few months and will be using BMS drivers but can't find them in winisd Beta not sure what to enter in for new drivers etc please can someone help me out Best wishes Flip |
Well my wife has kicked me out saying it's over due to my obsession with speakers don't know watt I'm gonna do with no ohm to go to
