  New Posts New Posts RSS Feed - 16 core 2.5mm cable
16 core 2.5mm cable
stevey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevey Quote  Post ReplyReply Direct Link To This Post Topic: 16 core 2.5mm cable
    Posted: 14 May 2012 at 1:46pm
Does anyone know if 16 core 2.5mm cable is available to buy in the UK. I’ve searched everywhere but can’t find any.  Thanks
100 volt line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 100 volt line Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2012 at 1:57pm
I think 18 or 19 core is available in YY and SY formats.  Lighting multicores IE socapex use 18 cores, so just get sme 18 core and dont use two of the cores !
I never did understand Millman's Theorem !
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2012 at 2:11pm
Yeah, I think that right, unless you want to place a big order for a roll of custom made 18G2.5 is a standard, Arena cables in Bishop Storfford do the AceFlex variant which is a bit nicer to handle than the normal stuff, Kelsey also do a LC-OF varaint in their ATM powerline range....
Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevey Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2012 at 3:54pm
Thanks for the advice. Yes I think I will go with the 18 core and keep
a couple of wires as spare. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2012 at 4:31pm
what are you up to with it?
[sorry, just being nosey]
Edited by mk2_ginger_biscuit69 - 14 May 2012 at 4:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevey Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2012 at 5:13pm
It was for speaker cable. I wanted to use the rubber H07 cable but I was told the YY cable was much cheaper. I always thought that the rubber cables were much better but I was told they are much more expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2017 at 3:58pm
is there any
16 core, 2.5mm ab out still
after a few metres
