  New Posts New Posts RSS Feed - 16a plug - safe or not without distro?
tobylee4242 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tobylee4242 Quote  Post ReplyReply Direct Link To This Post Topic: 16a plug - safe or not without distro?
    Posted: 20 August 2018 at 5:11pm
Hi all,
I've got a booking coming up where I need to power the whole setup (proline 3000, 2x TA2400 and dbmark processor) off a 16a industrial socket (the blue ones). Will I need a 16a to 13a distro, or will it be safe to power off a 16a industrial socket to 13a household socket adaptor? like this one https://cpc.farnell.com/pro-elec/pel00158/lead-single-13a-skt-16a-plug-1/dp/PL14283?st=16a%20plug%20to%2013a%20sockets
TMH Music View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMH Music Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2018 at 5:37pm
The lead you have linked to will be fine, as the plug that plugs into the 13a socket is fused at (surprise surprise) 13a!!! But why not take advantage of full supply and use something like this:
Plug the proline into one socket and the rest into the other socket. Just as a side note, some don’t like doing this, as it relies on the 16a socket being properly installed, but you, of course, will take steps to ensure the supply is wired correctly and properly protected; under these circumstances, it should be fine.
Nothing is foolproof because fools are so ingenious
Post Options Post Options   Thanks (0) Thanks(0)   Quote tobylee4242 Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2018 at 6:08pm
Good to know, thaks for the advice!
