  New Posts New Posts RSS Feed - 16ohm speakers
16ohm speakers
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Topic: 16ohm speakers
    Posted: 24 January 2023 at 6:20pm
is there any disadvantage of using 16ohm speakers you are aware of? i am not, so i'm also wondering why are they not more common - in particular, my use case, which is in double 18's so presenting a 8ohm load.
i've found some for a good price so hope to buy them.
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2023 at 6:57pm
They will be alot harder to power and will need an amplifier twice as powerful as 1 for 8r drivers. So for me it doesnt make much sense. Although i know of 1 sound system who used to wire 4 16r subs in parrallel and bridge their 9001 on them and so managed to extract all of the amplifiers power across 4 subs.
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2023 at 7:50pm
If you have amplifiers with high voltage output potential ( i.e. most high power class d amps such as linear research/powersoft etc) then high impedance drivers, particularly in mid and high frequencies can make a lot of sense
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2023 at 11:01pm
yea fair play. it sucks not being able to afford drivers that one has to consider hooky stuff like this but here we are.
for anyone wondering, there are 16o 18tbx100 on blue aran for 200 quid :)
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2023 at 12:19am
Why do n you think they are counterfeit? I doubt blue Aran are selling knock off b&c ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2023 at 9:15am
Im sure last week i saw 8r versions on there for just ober 200. Maybe 235
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2023 at 9:38am
Remember, Dub sound called Jah Voice, were absolutely immense, when they had16R 1850 Scoops, and they would bridge 4x of them, across Crest 9001.
So if you have right drivers, in right cabs, right amp and wall juice you are on a winner.
I also personally think 16R Compression drivers, sound better than 8 ohm versions, (when correctly powered), maybe why the illustrious ASS MX600, tended to be supplied with 16R JBLs 2".
