18" and lowwww |
Post Reply | Page 12> |
vrsz
New Member Joined: 30 April 2019 Status: Offline Points: 7 |
Posted: 19 July 2019 at 2:47pm |
Afternoon All,
Huge lover of all things bass and have been for years!, I built an 1850 horn with my dad when I was 11, it rocked but I had to decommission it due to size :( I've spent some time poking around the forum loving the build posts. I'm looking to take on a personal project and really would appreciate a little guidance, please. The choice of drivers and cab choices is quite unnerving. Firstly, size / dimensions / weight is no issue at all, these cabs are going to permanently installed in a summer house and will not move for the foreseeable future. Yes, it will be TOTAL overkill, I fully understand that.. :) Ideally, I am looking for a cab that drops very low and moves buckets of air it doesn't need to be overly punchy. I'm into hip-hop, trap, lots of long rolling lows. I plan to build two cabs, one to start with. Again, I'm not particular about drivers either but would like an 18", I have a 2400 amp with lots of juice. Complexity of build is not an issue either, I have a decent table saw, lots of precise woodwork experience and "some" patience. If someone would be kind enough to recommend a build link that hits the brief, please; (18", power not an issue, size not an issue, drops very low, moves tons of air) I would be super grateful. I'd also like to post my own build thread once things are underway! Thank you all.. keep it low!! Sam.
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
Teadub
Registered User Joined: 13 April 2019 Location: Highlamds Status: Offline Points: 29 |
Stipe's MS-18 mk2 could be worth a look. I have a pair and the depth still impresses me every time. Should sound sweet on hip hop too.
njw
Old Croc Joined: 26 March 2010 Location: S. Wales Status: Online Points: 2574 |
So you want something low and loud and size isn't an issue, you'll be wanting an eaw bh882 aka 'big bertha';
bob4
X1, or some tapped horn (e.g. keystone), or ROAR/HROAR or Paraflex
Check out brian steeles website, he has a lot of information and documentation on his builds. He works very systematically, and has a certain nomenclature for his various designs (POC 1,2, 3 etc poc=proof of concept)
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
How big is the room that you want it to play in HxWxL?
vrsz
hello everyone, thank you for the great input, I’m listing all the options to work out what do go for! So my room isn’t massive, 5x4x2m I fully understand that whatever I build will be total overkill, but I just love bass... I’m sure you all understand!
At present it’s either the Big Bertha or Cubo 18! Thanks again please keep the suggestions flowing in!!
toastyghost
In that size room you should just build a big, low tuned dual 18” reflex or a large tapped horn. A full size horn will be a waste and just upset the neighbours.
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Offline Points: 1834 |
and just how far away are the neighbours? one of the problems with bass is that it doesnt like to stay where you put it.
LOUDER THAN LOUD
vrsz
Hello all, lovely day in the UK (for a change).
Yep, fully aware that what ever I build will be overkill for the intended space, I have very good neighbours who often pop over for a mini-rave which is cool. For ease of build I'm looking at the Cubo Sub. I will mount the driver (magnet in chamber) for slightly higher output, thanks for everyone's assistance getting me to this point. After some more research it would appear that many people are torn between drivers with some builders using PD1850s, some use PD186s, others use different brands and specs. May I ask, is there any definitive "best" unit that will work in the Cube Sub, please? Final question, please. This is definitely a newbie question. Would there be any advantage to be had by rounding / routing the journey that the air travels around the horn please, there are a handful of sharp bends, I wonder if curved edges could smooth the response at all? Thanks again everyone! Sam. |
mobiele eenheid
Thanks(1)
Personally I like it with the 18Sound 18LW1400, as you're going with the magnet inside the chamber, I would go with a driver that has a Qes below 0.3 and a Vas below 300 L. So in this case the (new) 1850 over the (new) PD.186. I like rounding of the corners because it looks cool but sound-wise it doesn't have any real advantages, as the dimensions are so small compared to the wavelengths of the (low) frequencies involved.
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
Thanks(1)
I have a Faital 18XL1600 available if interested, should work nice in the cubo sub.
