  New Posts New Posts RSS Feed - 18" BPH Turbo style cabs
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Topic: 18" BPH Turbo style cabs
    Posted: 12 August 2018 at 5:21pm
 So, since moving away from HD215's a few years ago and going to 18" reflex cabs I've enjoyed having that bottom octave that was completely missing with the HD's but I've missed that punchy 'in your face' sound that the HD's had so I decided to knock up some Turbosound TSE 118 style cabs to go on top of the reflex cabs.
 Apologies in advance for the quality of some of the photos and lack of detailed photos, I just took the odd photo as I was building.
 First job, lots of cutting with my diy saw guide;
All panels cut;
Carcasses assembled and battens added for the access panel;
 Then I fitted the baffles and guides for the curved piece;
 After that I made some cutouts for the speakons;
 To form the curved piece I fitted a load of battens around the guide/former pieces, then bent a sheet of 6mm ply over the top;
 Then I fitted the top panels, braces and sound reflector piece;
 Cutting out the braces;
 Fitting inserts for the access panels and access panel test fitting;
 I also knocked up some flared mids whilst I was at it Smile
 Front battens added and edges rounded over;
I did some testing after that, oh, and knocked up some horn boxes (I've stuck a new dust cap on that mid too!)
Filling and sanding (I HATE filling and sanding!);
 First coat of paint on;
 And the finished cabs;
 With the mid and top cabs;
 The comps are BMS 4550's and by christ they're good! I've never heard a 1" comp capable of going so loud whilst sounding so crisp and clear.
 I used the cabs in anger for the first time last night and was very happy with the results, I've got the punch back! Big smile
Dutchman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2018 at 9:26pm
That is some nice wood work over there. Bet it sounds good! Maybe you can make the HF cabinet have the same width as the other boxes? Would look lovely :)
We need more SPL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2018 at 4:29am
What drivers have you put in the 118s and how low and high are you runnign them?
I assume you've used the 118 plan from hornplans.free.fr?
catalin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote catalin Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2018 at 5:56am
Nice work!!Clap
Mid flare is 12's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2018 at 1:46pm
Very nice works bro
like the way you have done the panel sections then the curve the ply onto it
keep up the good works
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2018 at 2:22pm
Good job.
If you can spend the time trying diff 18" drivers with diff voice coil sizes and cone weight, LMS eq/xover settings, on the 118s, you would be amazed at the freq resp you can obtain!!!
Did this when I had THL818s, results defied accepted rules for 18".
Edited by levyte357- - 13 August 2018 at 2:24pm
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2018 at 5:14pm
 Thanks, I deliberately made the top box just as big as it needs to be as I don't have a lot of storage space and am also space limited when transporting the cabs. Oh, and yes, they do sound good!. Smile
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2018 at 5:31pm
 At the moment the 118's are loaded with Peavey 1801 Black Widows (don't laugh!) as I had a pair sat on the shelf doing nothing, they seem to work surprisingly well! I've got reflex 18's doing 35-100, the 118's running 60-180, the mids 180-1.2k and the tops 1.2k and out. I had to have a play with the delays and phase due to the overlap on the bass cabs but I've always found this seems to give a much fuller, rounder sound than running the two types of bass cabs in separate frequency bands. My initial thoughts were to run the 118's up to 150 as the HD's I've used previously used to get really honky above this but these 118's seem to sound a lot cleaner at higher frequencies so I've run them higher to take some pressure off the mids.
 This is the plan I used but with a few small alterations;
I can't even remember where I got it from, I've had it stored on my laptop for ages.
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2018 at 5:35pm
Originally posted by catalin catalin wrote:
Nice work!!Clap
Mid flare is 12's?
 Thanks, yes, they're basically a narrowed Altec M17 which I realise is an ancient design but I've built some before and had good results so stuck with what I knew. They're loaded with Fane Studio 12L's and sound lush....
......and bloody loud! LOL
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2018 at 5:40pm
Good job.
 Thanks, different drivers are definitely on the cards at some point, as said, they're loaded with Peavey 1801's at the moment and whilst they sound surprisingly good in these cabs I have a feeling they're not going to last very long.
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2018 at 5:47pm
Originally posted by Dub Specialist Sound Dub Specialist Sound wrote:
Very nice works bro
  Thanks, I got the idea to do the curved piece this way after seeing an ASS BS1200 being cut down into two separate cabs, this was how the curved pieces seemed to be done in that cab. Smile
 Edit; I took some inspiration for the big central brace from that cab too.
Edited by njw - 13 August 2018 at 5:49pm
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2018 at 10:47am
nice Thumbs Up
