  New Posts New Posts RSS Feed - 18" BR 18XL2000
18" BR 18XL2000
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Topic: 18" BR 18XL2000
    Posted: 20 August 2023 at 1:11pm
As some may have seen already on some fb forums, I have designed and build a new 18" BR cabinet using the Faital Pro 18XL2000 driver.
Tuning is 32Hz with a port of 540cm2. Net volume is around 140L.
I have some pics of the build and response, but have to find a new website to host the images.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2024 at 2:50pm
Some info regarding this project.
Feel free to build, if you have any questions, you can post them in this thread.
REW outside measurement:
Link for the 3d file:
‚Äčhttps://drive.google.com/file/d/1fnq_1bcXvzdAuWz-he1j3bfjDSR7xagp/view?usp=drive_link
turbo7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turbo7 Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2024 at 1:26pm
Hi, looks very good. Plays deep and flat !
 I cant see the picture
Can you send a screenshot ?
Edited by turbo7 - 19 January 2024 at 1:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2024 at 8:19pm
That is very inefficient.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2024 at 10:48pm
Won't get more efficient for a BR. Maybe lower mms driver or lower re driver to get numbers up, but a 18XL2000 in this volume is quite it. No magic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2024 at 1:17am
Slightly bigger cabinet will gain 2db at 40Hz. But if compact was the idea, then all good.
fudge22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fudge22 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2024 at 12:23pm
Quote That is very inefficient.
There is a nice spike in efficiency at 50Hz.
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2024 at 1:20pm
Yup, we are all just Hofmann's bitches in the end, like it or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2024 at 9:41pm
End result with build in plate amps (i know what they resemble Wink).
Each sub can be used for multiple setups including 2.1.
Happy with the result, go low, but still sound tight.
Currently busy with a side project to build some amp modules around my own dimensions. A lot of the current (cheaper) options have basic plates that in most cases are quite wide. But that project will take quite some time and research to get some parts at a good price and will be a whole other topic when its time.
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2024 at 5:21am
Hi, What Plate Amp did You use???? Thanx, Vectordj
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2024 at 11:06am
They are from OMB audio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2024 at 12:17pm
How do you find the DSP on those? I got few amp plates to test and they just sit there on the shelv for years now. Horrible DSP.
