  New Posts New Posts RSS Feed - 18” HOG scoop best drivers ???
UGF k9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UGF k9 Quote  Post ReplyReply Direct Link To This Post Topic: 18” HOG scoop best drivers ???
    Posted: 15 April 2019 at 10:39am
Currently in the middle of building 9 hogs as a new rig build and wanted some opinions on what drivers I should use and why I was looking at loading them with pd1850 but can be very expensive is there any cheaper alternatives but with the same kind of quality !??
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2019 at 11:02am
Oberton XB1500 is a great replacement for PD 1850. B&c 18DS115 probably would be  a killer in hogs but not Sure of the Magnet even fits and its not cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UGF k9 Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2019 at 3:20pm
Cheers mate deffo look into it I’ve been looking at fane colossus and also eminence drivers would they be any match for the drivers you mentioned 👍🏻👍🏻??
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2019 at 6:08pm
Hogs loaded with oberton 18xb1500 here , nice and tight high spl sound albeit found the cones a bit fragile in the long run. Had a few pop on some hefty material. But for the price excellent choice.
Would recommend to buy some first class drivers as you will probably want to upgrade sooner or later.
b&c sw115 ds115
oberton 18xb1500 and 1600
pd 1851 or 1852 or 1850 but they can be a bit easy to burn the coil if you arent careful enough.
The b&c ones can take a beating.
Theres some rcf and 18sound candidates as well. The hogs can take lots of drivers it all depends what sound are you after.
