  New Posts New Posts RSS Feed - 18 inch speakers
18 inch speakers
Rog View Drop Down
Rogers Archive Posts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog Quote  Post ReplyReply Direct Link To This Post Topic: 18 inch speakers
    Posted: 13 October 2004 at 3:27am
well i got 2 18'" eminence omega pro they are 800 watts rms i was wondering wich box its my best bet? im going to be playing Rap Regue and all kinds of music, i also own four JLB JRX125 they have two 15 inch speakers and a horn, they are rated at 500 watts rms here is the website if u want to see them http://www.djplanet.com/expanded_detail.tpl?cart=10976350533 1602161&SKU=JRX125&IMAGE_EXIST=Y
i just need advice on the cabinet for the eminence speakers i bought thanks!!!
dubsuction View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubsuction Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2004 at 9:27am
hi Felipe!
have a look in the sub designs section of the speaker plans site....the c sub and the 184 sub are both suitable for the omega pro drivers...
...or you could design a direct radiating, vented cabinet...in which case you would need to calculate the volume of box required to suit the driver and the width and volume of the vents or ports to suit the box volume.....this can be done on a program such as boxplot which i believe is in the links section of speaker plans site....this may not be the most advanced program but i had good results when using it to design vented cabinets for some eminence sigma pro 650's....
...the plans on this site will i'm sure be more efficient and therefore better subs....but i'm not sure what will work best with what you already have.......
hope that this is of some use........anyone else?
cheers
peace+respect-always
**HIGH PRESSURE SOUND SYSTEM**
www.highpressuresound.co.uk
whitehousejamie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2004 at 10:07am
Yes, as Dubsuction says, the C Sub or 184 sub are suitable for the Omega.
