  New Posts New Posts RSS Feed - 18” Kickbin
18” Kickbin
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Topic: 18” Kickbin
    Posted: 04 August 2022 at 2:02pm
So this kick is pretty nice from what I’ve heard so far , am building two more for the guys who own the sound , they have them on scoops , with Floodlights on top sound really good together
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2022 at 3:34pm
nice up to 180?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2022 at 4:08pm
nice up to 180?
With these types of kicks, just needs careful tuning eq, to obtain  smooth  80-300hz.
I have a video somewhere, of original Turbo 818 with Fane 18xb, running to 400hz, clearly playing low mid vocals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2022 at 4:21pm
nice up to 180?
This one is from some box builder in Uk known for their work , due to high cost of plywood he said i could do the two , he says they do 250hz with no problem , will have to test that , I put this up cause of you Lev £, i didn’t bother to how low the go, i always worry about how high they can go instead .
JulianDA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JulianDA Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2022 at 4:28pm
Originally posted by Father-Francis Father-Francis wrote:
[QUOTE=cravings]nice up to 180?
May i ask why you then chose a BP-Design which by default has an internal lowpass-filter due to the resonance chamber?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2022 at 5:35pm
BP Design with 18", not as simple to get flat 80-300hz, as 2x15 reflex, but the SPL 80-160hz,  from 1x18 cab, is immense, and great outside, even upto 25M away, in stacks of 4x or more.
Edited by levyte357- - 04 August 2022 at 5:36pm
