18” Kickbin |
Father-Francis ![]() Old Croc ![]() ![]() Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2760 |
![]() ![]() ![]() ![]() ![]() Posted: 04 August 2022 at 2:02pm |
So this kick is pretty
cravings ![]() Old Croc ![]() ![]() Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7424 |
nice up to 180?
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8089 |
With these types of kicks, just needs careful tuning eq, to obtain smooth 80-300hz. I have a video somewhere, of original Turbo 818 with Fane 18xb, running to 400hz, clearly playing low mid vocals.
This one is from some box builder in Uk known for their work , due to high cost of plywood he said i could do the two , he says they do 250hz with no problem , will have to test that , I put this up cause of you Lev £, i didn’t bother to how low the go, i always worry about how high they can go instead .
JulianDA ![]() Registered User ![]() ![]() Joined: 29 May 2018 Location: Soest, Germany Status: Online Points: 110 |
May i ask why you then chose a BP-Design which by default has an internal lowpass-filter due to the resonance chamber?
BP Design with 18", not as simple to get flat 80-300hz, as 2x15 reflex, but the SPL 80-160hz, from 1x18 cab, is immense, and great outside, even upto 25M away, in stacks of 4x or more.
Edited by levyte357- - 04 August 2022 at 5:36pm |
