18" Reflex |
boots-hifi
Old Croc Joined: 15 August 2011 Status: Offline Points: 2463 |
Posted: 10 October 2018 at 12:12pm |
Looking for a pair or two, single reflex to sit under twin 15" wedges. The lower theyre tuned the better although i need to be able to move them by myself. Can be loaded or unloaded. No preference on desingn just seeing whats out there otherwise ill build something. Cheers
APW
I have a pair for sale, they are 18mm 13 laminate ply (but
not birch) and currently loaded with Eminence 18” Omega Pro’s, Measurements are
688mm wide, 566mm deep and 536mm tall, internal volume is about 152Ltrs net,
and the cabinets are currently tuned to about 40hz. The two ports are 100mm
drain pipe and so you can easily change the tuning to whatever you wish. I'm open to sensiable offers. I still have 6 of these cabs in total (I did have 10 4 of them had 15" drivers), one pair are still fitted with the Emmi drivers, the other 4 are now fitted with Celestion FTR18-4080HDX drivers, tuned accordingly and are not currently for sale. The cabinets are the same as these, however these were fitted with 15" drivers and had different tuning. . Edited by APW - 10 October 2018 at 2:40pm |
