  New Posts New Posts RSS Feed - 18 sound 18" design
18 sound 18" design
discodave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote discodave Quote  Post ReplyReply Direct Link To This Post Topic: 18 sound 18" design
    Posted: 13 May 2009 at 4:03pm
iv been given two 18 sound disigned boxes any iders if an other driver apart from 18 sound will work ie b&c fane pd turbomax
Post Options Post Options   Thanks (0) Thanks(0)   Quote discodave Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2009 at 12:43am
any body
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2009 at 1:06am
typical answer here would be work out it's volume, work out the port sizes, and stick all that into winisd.. then try putting in different drivers you have available?
or start comparing specs of recommended 18sound ones with others and find something similar....
FUBARD303 View Drop Down
Contentiously righteous
Post Options Post Options   Thanks (0) Thanks(0)   Quote FUBARD303 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2009 at 3:23am
Damn and I was hoping this had to do with 18sound boxes... Hey just get WIN ISD n build your own box using they're cool port flaring technique.
"Always look on the bright side of life" -Brian
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2009 at 8:52am
Yup, there are lots of drivers that will work in those cabs.  Anything recommended for the G-Sub, the B&C Sub18 etc will work.  That doesn't however mean that they'll all sound the same though.
The 18LW1400 is the most accurate and musical driver for 18" reflex boxes that I've heard but it comes down to personal preference.
