18" subwoofer or not? |
Page 12> |
Jack1991 ![]() Registered User ![]() Joined: 05 February 2020 Location: Bristol Status: Offline Points: 454 |
![]() ![]() ![]() ![]() ![]() Posted: 03 July 2022 at 4:49pm |
I got a small 12v sound system, for subs i use up to 4x Tham 12s. All 8Ω It runs off a car amplifier, Pioneer 8704. When running 4x thams the way its wired each sub recieves 50w (total 200w). When running just 2 subs the way its wired each sub gets 150w (total 300w) Id like to build 1x 18" sub to use instead sometimes, i know its alot heavier and bigger but be fun to build and looks alot nicer! Im just not sure on if it would sound better/louder/lower. Id only have to buy the speaker driver itself as the wood is offcuts from a friend. If i have just 1x 8Ω sub though then as far as im aware the only way i can wire it to that amplifier, it would only recieve 150w. I understand that 4x 12" speakers the surface area is greater than 1x 18" speaker. But im not sure if that works out the same way for if its say a 1850 horn sub because of the horn path etc? Also if it is worth me building one do you have a good suggestion for what one to build please? I had my eye on the 1850 but been reading around and see alot of people say the 1850 and 186 are pretty old now and there is better modern ones, but dont seem to say what ones they are. Cheers
Edited by Jack1991 - 03 July 2022 at 4:55pm |
Line Array ![]() Registered User ![]() Joined: 19 March 2022 Location: New Jersey, USA Status: Offline Points: 83 |
where are you using this system - in a car ? outdoors ? small room ? large space ?
best place on the internet >>>
https://dissidentsound.discoursehosting.net |
Outdoors
Jo bg ![]() Young Croc ![]() Joined: 08 March 2017 Status: Offline Points: 551 |
Consider a double 15 or double 12… you need efficiency on batteries, not a 18 with a lot of excursion you will not use.
Cool yeh ok, any particular plan or do you mean just design my own double reflex cabs?
The Tham12s are good i rekon but just wondered if theres anything else i could build that would be better. Edited by Jack1991 - 04 July 2022 at 9:11am |
eyeT ![]() Registered User ![]() ![]() Joined: 10 April 2016 Status: Offline Points: 69 |
Two Tham 15? The 4r load on the amp works out well and the Tham 15's do deliver. |
Cool yeh ive heard they are good. Was hoping for something different to a Tham though as got the 4 tham12s. Be nice to build and hear something different really.
Plan would be to have 1 sub box and then 1 midtop. Thats why was thinking a 1850. But didnt know about the excursion.
fatfreddiescat ![]() Young Croc ![]() ![]() Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1048 |
1850 was designed to work in multiples, as are all but the immovable front loaded horns that do bass, I'm guessing the 4 thams 12's are going to be hard to beat for output within their design bandwidth with a single driver / cab.
smitske96 ![]() Young Croc ![]() Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1009 |
Do you want to go lower? Then maybe its worth looking at something like a keystone or xoc1 TH18.
Ah ok cool i did wonder if they were pointless using on their own. And yeh thought the tham12s may be best for what im using.
I guess it would be cool if it goes lower. Basically i just wanted to build 1 sub that would be louder or at least equal to (loudness) either the 2 or 4 tham 12s. If it goes lower that would be good too. Be nice to make something different and new and to hear how it sounds. Also nice to just have 1 box even if it is 1 bigger heavier box thats ok. I assumed to achieve this id need to go 18". That Xoc TH18 looks a beast! I like that. Not a fan of the look of the keystone.
Edited by Jack1991 - 04 July 2022 at 12:15pm |
I'll get shot down for this, maybe. But if yr looking for an immovable cab. What about a Jensen Imperial with a 4r driver? It is the Platinum Jubilee after all, 1952 design.... If you have the wood....
LjudLahger ![]() Young Croc ![]() Joined: 31 July 2008 Location: Sweden Status: Offline Points: 838 |
Upgrade the amp?
What drivers in the thams?
Page 12> |
