  New Posts New Posts RSS Feed - 18" Super Scooper advice
RJ1995 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RJ1995 Quote  Post ReplyReply Direct Link To This Post Topic: 18" Super Scooper advice
    Posted: 16 July 2017 at 10:01pm
This weekend I started the build for the Mogale 18" super scoop. At this point I've got everything cut ready for assembly, picked up a pair of subwoofers for a bargain price so I'll have to build a second one later, this is the trail run!
My question is regarding the filtering, as stated on the design plans, the driver becomes unloaded below 30Hz. I've got an old active crossover at my Dads house I'll use to filter the treble and mids out before going to the scoops but what do I do about filtering below 30Hz? I was certain I'd be able to find a device for this after a quick google but unsure what to get. Any suggestions?
Any help would be greatly appreciated
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 12:07am
DBX DriveRack
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 12:20am
Depending on the amp you have it may have a hi pass on it .
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 10:14pm
Look at amp and crossover. You are looking for High Pass Filter (HPF). Even cheap Berry has 25hz one
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2017 at 6:46pm
25hz filter next to no help here.
Get Behringer DCX 2496 Ultradrive.
You will need between 35-38hz, 18-24db slope, depending on amps, drivers, processing.
Post these types of questions in Scoop Forum, no where else.
With right Scoops, drivers, amps, experience, you can then think about running Scoops down to 32hz, and playing gig all night, without blowing anything.
 Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2017 at 6:14pm
Dont built it LOL
only joke everyman to there own
