18 TBX 100 cone repair |
Marko
Registered User Joined: 28 January 2009 Location: Croatia Status: Offline Points: 274 |
Posted: 30 April 2019 at 4:21pm |
Hello!
I have 2 drivers B&C 18 TBX 100 that after 8 years of use get this same problem... Cone started to unglue from surround. Does anyone managed to fix this kind of problem or recone is the only solution? |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8707 |
Just glue it again, blue arran sell the glue you need http://bluearan.co.uk/index.php?id=FLXGLUEBLK&browsemode=manufacturer
Marko
Thanx SamV.
I will try.
Chris Grimshaw
Registered User Joined: 10 September 2018 Location: Sheffield Status: Offline Points: 281 |
FWIW, if you apply glue at one side, I'd recommend doing the other side (or all the way around) so that the mechanical load stays even. Chris
Quality sound from Sheffield
www.grimshawaudio.com |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
Check for over-excursion. looks like you are getting pretty close to X-mech. Maybe increase the highpass frequency of slope? |
