  New Posts New Posts RSS Feed - 184sub?
184sub?
Morison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morison Quote  Post ReplyReply Direct Link To This Post Topic: 184sub?
    Posted: 12 January 2005 at 11:11am
Hi all,
I've been looking at the bandpass designs on the site, and am curious about the 184sub. The performance graph suggests it's very nearly as good as the X1, yet it's a much smaller box. Is it really that good, or is there some limit to it's performance that the graph doesn't show? (I know it's an older design - was it done with less accurate modelling or something?) Also, would it benefit from a newer driver like a Void or P.Audio and if so, which one?
Cheers,
David.
whitehousejamie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2005 at 11:23am
Not sure about the 184 vs X1 in terms of output, but the P Audio SD18 would probrably be a good choice of driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2005 at 9:21pm
The X1 will go lower and has a higher output.
A driver like the Void 18 1000 has a high electrical powerhandling as well as a high mechanical powerhandling resulting in the ability to go low and loud.
The low Qts and high Bl (Void and SD-18) result in a strong and efficient motor which again will result in a higher SPL. It will also benefit the transient respons.
Edited by mobiele eenheid
